Hey everyone,
I’m looking at building my first proper server computer through a combination of new parts and some old ones I have lying around. I had a ‘server’ previous to this that I would keep in my living room and use for playing media and games off my TV, but some of the components gave out and the case was really big which my girlfriend didn’t like. We’re moving into a new place with a bit more space so I’ll be able to keep this one in my office. As my media library expands (currently just running an external HDD bay hooked up to an NVIDIA Shield running Plex which I backup manually to a second drive whenever I add new media), being unhappy with the performance of the Shield, and my desire to self-host more things for greater control, I’m pulling the trigger on a new proper server.
As this is my first time actually building a server from the ground up with more than just old parts from previous gaming computer builds and my friends, I’m asking for some more feedback and any tips.
TLDR: Building a new computer from previously owned and newly purchased parts. The server will be running Unraid with the *arrs, Plex, several other self-hosted apps. Server will only be used on a local network to start and maybe opened up down the line so I’ll be able to access everything and friends/family for Plex. Check the questions section for what I really want to know.
The Build
PC Part Picker link for those who prefer
| Component | Model | Amount | Price (each) | Total | Source |
| CPU | Intel Core i3-13100 3.4 GHz Quad-Core Processor | 1 | $199.99 | $199.99 | Best Buy |
| CPU Cooler | Noctua NH-D14 64.95 CFM CPU Cooler | 1 | $0 | $0 | Previously Owned |
| Motherboard | ASRock Z690 Pro RS ATX LGA1700 Motherboard | 1 | $199.99 | $199.99 | Newegg |
| RAM | Corsair Vengeance LPX 32 GB (4 x 8 GB) DDR4-3600 CL18 Memory | 1 | $129.99 | $129.99 | Amazon |
| GPU | MSI VENTUS XS OC GeForce GTX 1660 6 GB Video Card | 1 | $0 | $0 | Previously Owned |
| Case | Fractal Design Define R5 ATX Mid Tower Case | 1 | $189.99 | $189.99 | Newegg |
| PSU | Corsair AX760 760 W 80+ Platinum Certified Fully Modular ATX Power Supply | 1 | $0 | $0 | Previously Owned |
| Case Fan | Noctua A14 FLX 68 CFM 140 mm Fan | 5 | $0 | $0 | Previously Owned |
| UPS | CyberPower CP1500PFCLCD UPS | 1 | $314.99 | $314.99 | Canada Computers |
| Storage | Dell HBA330 12GB/s Mini Mono SAS HBA - P2R3R | 1 | $192.36 | $192.36 | eBay |
| Storage | Seagate Exos X16 16TB (ST16000NM002G) | 2 | $258.72 | $517.44 | eBay |
| Storage | Western Digital Red 4 TB 3.5" 5400 RPM Internal Hard Drive | 1 | $0 | $0 | Previously Owned |
| Storage | Western Digital WD_BLACK 2 TB 3.5" 7200 RPM Internal Hard Drive | 1 | $0 | $0 | Previously Owned |
| Storage | Samsung 870 QVO 2 TB 2.5" Solid State Drive | 1 | $0 | $0 | Previously Owned |
| Modem | Technicolor TC4400-AM | 1 | $0 | $0 | Previously Owned |
| Router | TP Link Archer AX1800 | 1 | $0 | $0 | Previously Owned |
| Grand Total | $1,744.75 |
Notes
- All prices are in CAD. For eBay sellers, prices listed are after conversion from USD and include shipping + taxes
- Will run Unraid as an OS with a RAID1 setup
- 2x12TB will be in the raid setup. Additional HDDs will be used for torrenting and storing things not necessarily used by the server apps.
- Running Plex (with Plex Plus for hardware transcoding), Sonarr/Radarr/Lidarr, Requestrr (Discord bot), Navidrome (music server), BookStack (wiki), NextCloud (file hosting), PiHole, and a torrenting client (Deluge) 24/7
- All will be running in Docker containers (hopefully anyways as it will be my first time using Docker)
- SSD to be used for Plex database/metadata
- Anything else worth putting on here specifically? Usually I would put the OS, startup apps, games on the computer but what do I do with a server? Games I plan to play via remote play I suppose?
- Some parts (such as the video card) I already have and are indicated on the spreadsheet
- The server will be in an office on the 2nd floor with two clients: an NVIDIA Shield on the first floor in my living room and then my gaming computer in the same office as the server. Ideally everything will be wired but I’ll need to fish a cord through my wall to reach the living room/Shield
Questions
- Is it all compatible? I’m comfortable with compatibility on most of the parts however this is my first time using SAS connectors for the HDD. As I only have SATA ports on the mobo I need to use the HBA to plug into a PCI-E slot and then connect the HBA to the SAS HDDs, is this correct?
- My understanding is that there’s no performance difference or other considerations to take into when using the HBA vs. onboard SAS connectors
- Will SATA power cords work with SAS HDDs? I’ve read conflicting older comments online but from pictures I’ve seen it looks like the SATA would be fine
- Looking to make this as quiet as possible, any tips or suggestions?
- Not necessarily attached to the case so I’m really open to suggestions here. Ideally I want it to be sleek, easy to work inside of, and quiet
- Is this overkill? Any parts you’d recommend swapping out in favour of others?
Down the line
- Opening up the server to the internet so I can access it remotely and set my family up on Plex
- Eventually will build a NAS for backing up data on the server and moving NextCloud and maybe media files for Plex
- Setting up the machine to remote play once I have the server apps figured out and setup
- Potentially running game servers (Minecraft and Valheim are the only two that I think I would run at this time)
Thanks for reading all that and for any feedback in advance! Let me know if I need to clarify anything too.
