WIP Post
| Reinhardt | ||
| Hardware | ||
| CPU | Intel Xeon E3-1220L V3 SR1BT 1.1GHz LGA1150 13w CPU Processor 1220LV3 | $27.00 |
| Serverboard | Supermicro X10SL7-F Motherboard High Performance LGA 1150 | $50.00 |
| RAM | 32GB (4 x 8GB) Hynix PC3L-12800E DDR3-1600 ECC Unbuffered RAM HMT41GU7BFR8A-PB | $95.00 |
| Drives | ||
| Parity | WD easystore 10TB HDD (WDBCKA0100HBK-NE32) | $169.99 |
| Disks | 3x WD easystore 8TB HDD (WDBCKA0080HBK-NESN 256mb White) | $479.97 |
| Hitachi HGST 8TB 7200RPM 3.5" 12Gb SAS HARD DRIVE HUH728080AL4200 4KN 0F23651 | $89.00 | |
| Boot | SanDisk Cruzer Fit CZ33 16GB USB 2.0 Low-Profile Flash Drive | $6.99 |
| Cache | HGST Hitachi SN100 1.6TB eMLC PCI Express 3.0 x4 NVMe U.2 2.5" HUSPR3216ADP301 | $135.00 |
| Chassis | ||
| Chassis | Rosewill RSV-L4500 4U Rackmount Server Chassis with 15 Internal Bays and 8 Fans | $109.99 |
| CPU Cooler | Arctic Freezer 12 CO CPU Cooler 92 mm PWM Fan Up to 130 W TDP | $24.99 |
| Fans | ARCTIC F12 PWM PST Low Noise 5-pack | $24.99 |
| 2x ARCTIC F8 PWM PST Low Noise | $8.00 | |
| PSU | Seasonic 650W 80+ Gold Certified ATX12V/EPS12V SSR-650RM | $69.94 |
| Parts | ||
| U.2 PCIe Adapter | Dilinker U.2 to PCIe Adapter - x4 PCIe - for 2.5" U.2 NVMe SSD (PEX4SFF8639) | $28.88 |
| SAS Expander | HP 487738-001 468405-001 24-Bay 3Gb PCI-e SAS Expander Card | $8.00 |
| Reverse Breakout | 2x Cable Matters Internal Mini SAS to SATA Reverse Breakout Cable (SFF-8087 to SATA) 1.6 ft | $27.98 |
| SATA Breakout | 2x Mini SAS to 4-SATA SFF-8087 Multi-Lane Forward Breakout Internal Cable 3 Feet | $12.89 |
| SAS Breakout | CableDeconn Mini SAS 36 SFF-8087 to (4) SFF-8482 Connectors with SATA Power 1m | $12.79 |
| SATA Power Splitters | 2x Cable Matters 15 Pin SATA to 4 SATA Power Splitter Cable - 18 Inches | $13.99 |
| 2x StarTech 4x SATA Power Splitter Adapter Cable | $11.28 | |
| Full Height Brackets | 5x Full Height Bracket for IBM M1015, M5015, LSI 9260-8i HP P400 P410 | $5.70 |
| Total | $1,381.40 |
