First post here, I’ve been lurking for months. I have put together a NAS Killer 4.1 and an HP 290 to serve up my Plex media. Love the forums @JDM_WAAAT, wealth of information presented in clear and concise format, and have been wanting to learn Linux after tinkering with some Pi’s.
Upgrading from a 2014 Mac Mini with external drives - the HP 290 ran circles around it with the upgraded 1TB NVME and 12 gigs of ram.
Today, I had an itch to upgrade the CPU in my HP 290 after seeing a deal on i5-9600k @ Microcenter ($150), and the improvement to performance is astounding - this thing screams. I was able to transcode 6 4K movies to 1080p across multiple devices at 30% CPU usage, even a few with subtitles.
My question for y’all, what max CPU temps should expect with the stock cooler/shroud before getting concerned? Currently idling around 30C, got up to 53C on all cores when transcoding. Not alarming from what I’ve read, and won’t be see that much action in normal usage.
I’m looking to build a low power plex transcoder with a decent amount of storage for the time being. I’ll be building out my NAS soon enough. I found this thread and it’s been incredibly helpful. I was able to snag a 290 locally for $80 practically brand new. What I am looking for is what all I need to add to it. I’d like to max it out storage wise as well add any other necessary options. It currently has a G4930, 4GB of Ram and a 500GB drive. Any suggestions for drives, ram or any other items is appreciated. I have already ordered a dummy plug.
Well if you’re just using it as a transcoder, there’s no reason to have onboard storage aside from the boot SSD where Plex metadata is also stored.
For optimal performance, I’d recommend a 256GB NVMe (unless you have a large library, then I’d go 512GB) and adding an additional 8GB of RAM to the 4GB that you already have.
That 8500T is key here and designed to be lower powered. I’m running the same processor on one of my headless builds with Ubuntu 20.04.1 server that stays on 24x7 along with the hdmi dummy plug.
I had posted this in another thread, but this setup is running at 4 watts idle. Before I upgraded to the 8500T, I thought for sure I’d be up over 40 watts idle. I’m glad I was wrong in that previous assessment.
Hi everyone. I’m having trouble with my Plex server not being able to properly transcode HVEC files for remote watching. My server currently runs an i7 3770k procesor, wich I’ve been told can’t decode the files. I just found this thread and from what I gather, I could build another server with a cheap 7th, 8th, 9th or 10th gen Dual Core Celeron procesor and get rid of my problem… is that right? At the most, I need it to be able to direct play 2 files locally, while transcoding a 3rd one remotely. I could get a Celeron G4930 for a very good price if needed.
Thanks for the quick reply! I have one more question if you don’t mind me asking. I always thought one had to check the CPU passmark benchmark to assess each CPUs ability to handle any number of streams… The G4900 that you tested has a very “poor” rating there compared to even my i7 3770. Is that a benchmark I shouldn’t be looking at anymore?
The passmark has very little to do with the iGPU’s ability to transcode! That is mostly generational, and the G4900 is 5+ generations newer than the i7-3770.
If you start small with the G4900, you can always upgrade the processor later.
Yes, it will show up as another interface, unless you disable it in the BIOS. Before you think about using it, make sure you update the driver following the directions in this thread. The included drivers aren’t the best, and can cause stability issues under heavy load.
