HDHomeRun & Plex
I found a Connect Duo model on ebay $59 (free shipping) so I plan on using that with Plex. I’ll have to purchase that $35 per year subscription to their service. I’m not sure what that’s for…I’m guessing they put together the guide for Plex and that costs money for up keep.
I decided to drop my local package on Dish Network which was costing me $12/month and there are a few channels that have been in dispute for well over a month now. In any case I don’t have any issue getting decent OTA signal so I think I’m done paying Dish for locals.
RE: remote viewing…would I be able to watch my OTA channels thru Plex remotely just like I can with my movies? I can’t see why not but wasn’t sure it worked that way.
I’m using an HDHR Prime with Plex, works great. I can fire up live TV on my phone and watch remotely as well. It was all pretty easy to set up. I think you can do a 30 day free trial of Plex Pass if you want to test before you pay.
Hd homerun is free to use. You wouldn’t pay them unless you want to subscribe to their DVR service instead of using Plex.
Ok…I misunderstood all of that. Some of the youtube videos about hooking it up to plex seemed to suggest it wasn’t optional.
I use it the way you described, but I do have Plex Pass, and I’m pretty sure that’s required.
Yes I believe it says plex pass is required. I’m good there. I should be good to go then once it arrives.
I can confirm that I use my HD/HR with Ples. I pay nothing to HD/HR but do have a Plex Pass. Works fantastically
Got it today. Signal quality over what I had been using is a lot worse. I’m going to look at relocating the outdoor antenna in the next few days. I may end up getting one of those Omni directional models. I have a couple trees in the way of right where it needs to point.
I have been using plex pass dvr feature with hd home run quadro 4 tuner ever since that feature came out. Love it works well.
I replaced the cat 5 cable that came with the Hd homerun and my signal quality issues went away. I am still going to relocate my outdoor antenna but I don’t have to get in any hurry about it. I guess that cable is junk…was reading on reddit that several people said that cured their issues but that was from a few years ago.
EDIT: Can someone halp with recording permissions? I think it’s a matter of chown the plex media hard drive location. In my case I’m just going to use the local M.2 to record local shows on.
UPDATE:
To change permissions of your media folders, first add the plex user to your main user’s group
sudo usermod -aG plex
Then set the permissions of your media folders to 775 so your group (and the plex user member of that group) can execute files
sudo chmod -R 775 /path/to/media
sudo systemctl restart plexmediaserver
EDIT 2: Ok on my new android phone it wants to direct play everything and it plays great even with a weak signal. On everything else in my house it’s trying to transcode and the signal absolutely sucks. What the crap is going on?
Is there a “Build” for a Homerun substitute?
Not quite sure what you mean by substitute?
HDHR devices are great, I don’t see a particular reason to use something different.
Being Very new to all of this, I figured there was something that could substitute buying the HDHR product.
Ex: used the NAS build for my NAS
used HP T730 for my pfsense box
used HP Prodesk 400 G4 for plex/transcoder
- This machine will just be for plex. Could something be add to this to “substitute” for an HDHR.
This probably doesn’t make sense. Still learning. I have no Movies/TV and just built a 26TB NAS. Haha. Now I need to figure out how to use it!
My hdhomerun is run exclusively on my plex server for the last 3 months..
got a db8 antenna (check amazon on warehouse deals got mine with a 70$ discount)
had a channel on uhf that reception was spotty that my wife is always watching so I had to also install a 7 foot yagi in my attic to catch that one…
were really pleased with the setup besides one major hiccups with plex, if I don’t force my tv to transcode when we fast forward anything it will start back at the beginning of the show…
I think thing I dislike is the HDHR app on Roku is hit and miss but I can go over to Plex and everything works fine. I do like the quicker loads and access on the HDHR app. I understand it works better if you are a DVR subscriber but I’m not going through all that.
Before buying the HDHR duo I looked into scenarios where I would just buy a capture card/install directly to UNRAID server which to me made a lot of sense but never really could find anything and if I had plex probably wouldn’t have had any compatibility with it making it even more worthless. Years ago I had such a card from AverMedia using with Windows Media Center to record OTA shows and networking them thusly throughout the house. It worked ok but I didn’t have a lot of knowledge back then…HDHR takes that same concept and makes it much much better.
I’ve been looking at the HDHR cards for a while now and am curious what the consensus seems to be on which card to get. I know it depends on use case, mine is pretty simple really…just want to be able to have three different streams going to three different users which will all be on the internal LAN.
There’s no card that you should buy IMO, only the standalone network tuner boxes.
If you want 3+ streams, might as well get the top of the line 4K/quad tuner. I had this one for a while and it worked great. I only got rid of it because I don’t really watch live TV.
Tried to unflag my deleted post saying, “Thanks”, but it says I’ve tried too many times and can’t for 23 hours…anyway, Thanks for the advice JDM!
Stupid question, which antenna or amplifier do you recommend with this JDM?
