So I came up with the following build -
*DDR ECC RAM - 8x 32GB RAM. -Not sure on brand or type etc
*1TB SDD x8
*2x E5-2697 v3
*4x AMD R9 Nano
*Either Supermicor board (not sure which model - advise please or Asus Z10PE-D8 or D16 WS
Hey, its me again… I did build a new unraid server and now I have the issues again…
I am stuck again with error 43 and did double and triple check everything. The only thing I seem not be able to is boot in non UEFI. My board is a Gigabyte Z490 AORUS ULTRA-GU. I did tell the unraid stick not to boot in UEFI, but it got stuck at startup. I did find the CSM settings, but I think i may miss something.
Maybe someone here has a idea.
For your 1TB NVMe, follow the install instructions above. For the 2TB storage drive, you can pass that through as well in the VM config.
If you only have 30GB as your windows install disk, that’s just the initial size. You can expand it in Unraid. Then you will have to go to disk management in the VM and expand it there as well.
So what I ended up doing was adding the 1 tb nvme and 2tb ssd as their own cache drives, and installing the windows vdisk to the nvme as windows and then passing through the 2tb as windowsgames and creating the disk that way within windows. seems to work so far, but thank you for answering my question too. I’ll keep this in mind if I have to redo something.
Only question I have left is if I’ve got my xbox controller set up as a bluetooth controller on my Mac, will that passthrough to the vm?
Also any tips on why Moonlight stutters over a home network? I keep lowering the bandwidth and I’m still getting stalled out and skipping. I’ve got a RTX 2080 super water-cooled in the Unraid box.
Hardware is open ended. Right now I use a desktop as a nextcloud server and network share, and want to upgrade, I was looking at NASK 4 or 5. (The desktop was also my Plex server but I successfully used your guide to get that onto the HP-S01)
One GPU per instance is good to know. That kinda puts a limit on how many clients can use it at once, then, right?
Really just depends on how many GPUs you feel that you can cram into your server. I’ve personally used up to 3 GPUs without any issue. Single slots GPUs like the Nvidia P2000 help in this case, but the performance is pretty low compared to even “low” end GPUs like the 1660ti or 3060.
I don’t know if this has been mentioned yet but if you are just looking to do retro games and want to run on the Intel igpu without a dedicated GPU, you may run into issues with Parsec.
What an amazing tutorial. Followed instructions to the letter, however, ran into an issue with GPU passthrough but that was my bad since my Unraid USB booted in UEFI. Legacy boot fixed that. I had some questions however, I know theoretically a wired connection is optimal but I am sitting next to the router (Ubiquiti AC PRO) on a 5Ghz connection and it drops sometimes and causes a stutter? Is that expected?
My Vm runs on 6Cores12Threads and a 3060. Host is wired via ethernet. I saw @JDM_WAAAT youtube video and saw his decode encode times were below one milisecon. How is that achievable when my times for a 2k ultrawide client are around 5ms decode and 2ms encode. What could of went wrong for me? I tried hosting a session on my main rig with a 3080ti and the encode were not much better? I know I can fix my latency for network with a ethernet cable but what is happening to my encode decode?
Thank you for your input while I have you here might as well say a big thank you for all this effort.
What do you think might be the issue with the encode and decode latency? Yours was super low compared to what I am getting even on my wired rig. Wired rig to server i still get high numbers.
Encode ~ 4ms
Decode ~ 5ms
I am still a noob to all these latency numbers but my goal was to get as close to the numbers you were getting. What could I look for to fix this?
Im on Passthrough ~8.5. When editing the VM, it appears to not update and save the settings of removing the OS install and adding in the GPU in and Sound Card.
I get a Common Problems pop-up after letting it sit that says Legacy PCI Stubbing Found. Possible relation in issues?
I realise that this is an older thread, but I’m hoping someone on here will be able to help me out.
I followed the tutorial very closely (though not the whole parsec part, as I have no need to use the VM remotely, I just want to have it connected to a regular monitor)
But for some reason when I start my VM the screen remains black.
What am I missing? It launched fine in VNC, but now my monitor doesn’t get a signal and just turns off. I already tried a different screen and different port on the gpu, no use.
Hey, thanks, really appreciate it! And just as an update, I made a second setup with a Ubuntu VM and just copied over my GPU and CPU xml config, and with that one it’s working just fine, I’m getting an Image. So is there something I need to do in windows first?
