[Guide] Remote Gaming on Unraid
@dhawk2k
I’m not an expert with everything but thought I’d mention one thing. IF I was going to buy a seperate GPU just for Plex then I’d probably go a different route…I’d get a Shield TV and connect it to all of your media (media stored on Unraid server). This way your server is storing everything and has all the space, but the Shield TV is handling all the processing work. The shield has excellent video capabilities as well as excellent transcoding capabilities.
I did this so that it would take that load off my server resources so that I could dedicate more resources to my W10vm for gaming. Gaming hits the GPU and CPU hard and when you throw Plex into the mix at the same time your going to struggle…even with two GPU’s.
The latest Shield TV Pro is $200 so cheaper than a good GPU.
Thats just my opinion…I have a Shield and its tied to my Unraid server…works awesome and also brings a lot of other capabilities to the system.
Thanks for the suggestion.
I do get the idea of using a powerful android box to avoid transcoding.
My local clients currently use amazon 4k stick and fix enough to stream 4k hevc.
What I like to do is to stream remotely some transcoded 1080p videos 2-3 streams. My qnap nas is struggling and can’t keep up so going a fast server with it without gpu can handle this.
Which the included gpu can be use for remote having…
Plus I have some use for docker and other vm so I am stoked to try it…
when I update my graphics option to my GPU and hit update, then go back into edit VM, it has reverted to VNC. This is even before going into the XML view. I have my xml attached
<?xml version='1.0' encoding='UTF-8'?> TEST 457a0b48-fc48-4ec4-626e-42302f16ad99 4194304 4194304 12 hvm /usr/share/qemu/ovmf-x64/OVMF_CODE-pure-efi.fd /etc/libvirt/qemu/nvram/457a0b48-fc48-4ec4-626e-42302f16ad99_VARS-pure-efi.fd destroy restart restart /usr/local/sbin/qemu
Were you able to resolve your issue?
Nope, I was able to do it once. not sure how. but I kept getting the code 43 error, and the graphics card wasnt putting out the vm to my monitor. I figured it was because I’m running a z490 and 10700k and unraid isnt ready for this yet. IDK I installed windows and Im gonna put unraid on my older system. My preference would be to run it on my main, since I have 64gb ram and a good cpu.
Is my assumption that the most modern mobos and cpus might not work with the current unraid? I couldnt even get the stable to boot on it, had to use the beta
No, it should support everything just fine.
I followed your guide to a T, (other than the BIOS setup). I am running the MSI z490 MoBo. When I disabled UEFI boot, I was not able to boot any devices. I flashed the most current BIOS, and still no luck.
When Running UEFI, I am only able to boot the Beta Unraid, and was not able to boot stable. (I plugged the stable into an older system and was able to boot fine.
I followed all of the steps and the furthest I got was connecting via RDP to my vm which supposedly has my 1080 passed through, but then I get the error in device manager regarding my GPU. So I revisited the steps regarding editing the VM’s XML and BIOS passthrough, repeated multiple times to no avail.
I would love to make this work on my primary system. I have been pulling my hair out, and keep going back to the possibility that there is incompatible hardware.
You need to turn off UEFI boot in the Flash drive as specified in the guide and then turn it off in the BIOS. After that, select the proper boot device and it will be able to boot.
Your hardware is compatible, your GPU issues are likely stemming from the fact that you are booting in UEFI, not Legacy mode.
Hello!
I have the same issue as RexSpecs had. After the initial windows install i can no longer switch GPU from VNC. Only add as the second.
Im using unRAID 6.9 beta30.
Specs: ASUS X470-PRO – Ryzen 2600 – AMD 5700 XT
Everything went perfect up this point.
Worth a note is that this is not a problem on a linux VM I have, there I can switch between a GPU or VNC with no problem.
I have also double checked that it is booting in Legacy mode and not UEFI, though this does not appear to matter.
Delete the VM config, and create a new one with the appropriate GPU config using the old vdisk. I think it’s a new bug in unraid.
Thanks for the very fast reply, worked like a charm!
Ran into another issue. During the install of the GPU-drivers the screen went black (For ever, not the regular blinking). Stopped the VM and now it freezes during boot with one CPU core maxed out.
Should I just try reinstalling the VM?
EDIT: This was resolved my installing the VM with Q35 instead.
I added two unassigned HDDs to my VM with passthrough, but I had to do it through the XML interface.
Here is the code I used:
<disk type='block' device='disk'>
  <driver name='qemu' type='raw' cache='writeback'/>
  <source dev='/dev/disk/by-id/XXXXXXXXXXX' index='1'/>
  <backingStore/>
  <target dev='hdd' bus='virtio'/>
  <alias name='virtio-disk3'/>
  <address type='pci' domain='0x0000' bus='0x01' slot='0x01' function='0x0'/>
</disk>
  <source dev='/dev/disk/by-id/XXXXXXXXXXX' index='2'/>
  <backingStore/>
  <target dev='hde' bus='virtio'/>
  <alias name='virtio-disk4'/>
  <address type='pci' domain='0x0000' bus='0x01' slot='0x02' function='0x0'/>
</disk>
I used an entirely different PCIe bus that my other devices. Note that the alias name, target dev=hdx, and slot=0x0x musy be unique.
Hi there.
Really really awesome guide. it was very easy to understand.
however i’m having a bit of my problem with with mine and was hoping if anyone is able shed some light to what i might be doing wrong.
my setup:
gt10 ( only boot for the unraid )
rx590 ( for the vm )
3900xt
aorus master mobo
I’m able to boot into the vm and install the gpu driver and all went well. Even tried to play some games without any issue.
But every time i reboot, or shutdown from within the VM, the status under unraid vm tab will be in pause. i have to force stop and start again for the vm to start back up normally.
I also notice that at random times, after maybe 10hrs or just 30mins, the vm just suddenly stop. and the status under the vm tab is pause and i had to force stop and start again.
i’ve tried doing everything from scratch but still same problem.
VM logs:
-no-hpet \
-no-shutdown \
-boot strict=on \
-device pcie-root-port,port=0x10,chassis=1,id=pci.1,bus=pcie.0,multifunction=on,addr=0x2 \
-device pcie-root-port,port=0x11,chassis=2,id=pci.2,bus=pcie.0,addr=0x2.0x1 \
-device pcie-root-port,port=0x12,chassis=3,id=pci.3,bus=pcie.0,addr=0x2.0x2 \
-device pcie-root-port,port=0x13,chassis=4,id=pci.4,bus=pcie.0,addr=0x2.0x3 \
-device pcie-root-port,port=0x14,chassis=5,id=pci.5,bus=pcie.0,addr=0x2.0x4 \
-device qemu-xhci,p2=15,p3=15,id=usb,bus=pcie.0,addr=0x7 \
-device virtio-serial-pci,id=virtio-serial0,bus=pci.2,addr=0x0 \
-blockdev '{"driver":"file","filename":"/mnt/user/domains/Windows 10/vdisk1.img","node-name":"libvirt-3-storage","cache":{"direct":false,"no-flush":false},"auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-3-format","read-only":false,"cache":{"direct":false,"no-flush":false},"driver":"raw","file":"libvirt-3-storage"}' \
-device virtio-blk-pci,scsi=off,bus=pci.3,addr=0x0,drive=libvirt-3-format,id=virtio-disk2,bootindex=1,write-cache=on \
-blockdev '{"driver":"file","filename":"/mnt/user/isos/Windows/Windows10.iso","node-name":"libvirt-2-storage","auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-2-format","read-only":true,"driver":"raw","file":"libvirt-2-storage"}' \
-device ide-cd,bus=ide.0,drive=libvirt-2-format,id=sata0-0-0,bootindex=2 \
-blockdev '{"driver":"file","filename":"/mnt/user/isos/virtio-win-0.1.173-2.iso","node-name":"libvirt-1-storage","auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-1-format","read-only":true,"driver":"raw","file":"libvirt-1-storage"}' \
-device ide-cd,bus=ide.1,drive=libvirt-1-format,id=sata0-0-1 \
-netdev tap,fd=35,id=hostnet0,vhost=on,vhostfd=36 \
-device virtio-net-pci,netdev=hostnet0,id=net0,mac=52:54:00:96:02:d6,bus=pci.1,addr=0x0 \
-chardev pty,id=charserial0 \
-device isa-serial,chardev=charserial0,id=serial0 \
-chardev socket,id=charchannel0,fd=38,server,nowait \
-device virtserialport,bus=virtio-serial0.0,nr=1,chardev=charchannel0,id=channel0,name=org.qemu.guest_agent.0 \
-device usb-tablet,id=input0,bus=usb.0,port=1 \
-device vfio-pci,host=0000:0a:00.0,id=hostdev0,bus=pci.4,multifunction=on,addr=0x0 \
-device vfio-pci,host=0000:0a:00.1,id=hostdev1,bus=pci.4,addr=0x0.0x1 \
-device usb-host,hostbus=3,hostaddr=6,id=hostdev2,bus=usb.0,port=2 \
-device usb-host,hostbus=3,hostaddr=4,id=hostdev3,bus=usb.0,port=3 \
-device usb-host,hostbus=3,hostaddr=3,id=hostdev4,bus=usb.0,port=4 \
-sandbox on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny \
-msg timestamp=on
2020-11-25 17:33:36.792+0000: Domain id=10 is tainted: high-privileges
2020-11-25 17:33:36.792+0000: Domain id=10 is tainted: host-cpu
char device redirected to /dev/pts/0 (label charserial0)
2020-11-25T17:33:38.981677Z qemu-system-x86_64: vfio_err_notifier_handler(0000:0a:00.1) Unrecoverable error detected. Please collect any data possible and then kill the guest
2020-11-25T17:33:38.981784Z qemu-system-x86_64: vfio_err_notifier_handler(0000:0a:00.0) Unrecoverable error detected. Please collect any data possible and then kill the guest
XML:
<domain type='kvm' id='10'>
  <name>Windows 10</name>
  <uuid>6fa67aff-2d8b-3a6e-65b3-f103cb7ff06c</uuid>
  <metadata>
    <vmtemplate xmlns="unraid" name="Windows 10" icon="windows.png" os="windows10"/>
  </metadata>
  <memory unit='KiB'>8388608</memory>
  <currentMemory unit='KiB'>8388608</currentMemory>
  <memoryBacking>
    <nosharepages/>
  </memoryBacking>
  <vcpu placement='static'>8</vcpu>
  <cputune>
    <vcpupin vcpu='0' cpuset='8'/>
    <vcpupin vcpu='1' cpuset='20'/>
    <vcpupin vcpu='2' cpuset='9'/>
    <vcpupin vcpu='3' cpuset='21'/>
    <vcpupin vcpu='4' cpuset='10'/>
    <vcpupin vcpu='5' cpuset='22'/>
    <vcpupin vcpu='6' cpuset='11'/>
    <vcpupin vcpu='7' cpuset='23'/>
  </cputune>
  <resource>
    <partition>/machine</partition>
  </resource>
  <os>
    <type arch='x86_64' machine='pc-q35-4.2'>hvm</type>
    <loader readonly='yes' type='pflash'>/usr/share/qemu/ovmf-x64/OVMF_CODE-pure-efi.fd</loader>
    <nvram>/etc/libvirt/qemu/nvram/6fa67aff-2d8b-3a6e-65b3-f103cb7ff06c_VARS-pure-efi.fd</nvram>
  </os>
  <features>
    <acpi/>
    <apic/>
  </features>
  <cpu mode='host-passthrough' check='none'>
    <topology sockets='1' cores='4' threads='2'/>
    <cache mode='passthrough'/>
    <feature policy='require' name='topoext'/>
  </cpu>
  <clock offset='localtime'>
    <timer name='rtc' tickpolicy='catchup'/>
    <timer name='pit' tickpolicy='delay'/>
    <timer name='hpet' present='no'/>
  </clock>
  <on_poweroff>destroy</on_poweroff>
  <on_reboot>restart</on_reboot>
  <on_crash>restart</on_crash>
  <devices>
    <emulator>/usr/local/sbin/qemu</emulator>
    <disk type='file' device='disk'>
      <source file='/mnt/user/domains/Windows 10/vdisk1.img' index='3'/>
      <backingStore/>
      <target dev='hdc' bus='virtio'/>
      <boot order='1'/>
      <alias name='virtio-disk2'/>
      <address type='pci' domain='0x0000' bus='0x03' slot='0x00' function='0x0'/>
    </disk>
    <disk type='file' device='cdrom'>
      <driver name='qemu' type='raw'/>
      <source file='/mnt/user/isos/Windows/Windows10.iso' index='2'/>
      <backingStore/>
      <target dev='hda' bus='sata'/>
      <readonly/>
      <boot order='2'/>
      <alias name='sata0-0-0'/>
      <address type='drive' controller='0' bus='0' target='0' unit='0'/>
    </disk>
      <source file='/mnt/user/isos/virtio-win-0.1.173-2.iso' index='1'/>
      <backingStore/>
      <target dev='hdb' bus='sata'/>
      <readonly/>
      <alias name='sata0-0-1'/>
      <address type='drive' controller='0' bus='0' target='0' unit='1'/>
    </disk>
    <controller type='usb' index='0' model='qemu-xhci' ports='15'>
      <alias name='usb'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x0'/>
    </controller>
    <controller type='pci' index='0' model='pcie-root'>
      <alias name='pcie.0'/>
    </controller>
    <controller type='pci' index='1' model='pcie-root-port'>
      <model name='pcie-root-port'/>
      <target chassis='1' port='0x10'/>
      <alias name='pci.1'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0' multifunction='on'/>
    </controller>
    <controller type='pci' index='2' model='pcie-root-port'>
      <target chassis='2' port='0x11'/>
      <alias name='pci.2'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x1'/>
    </controller>
    <controller type='pci' index='3' model='pcie-root-port'>
      <target chassis='3' port='0x12'/>
      <alias name='pci.3'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x2'/>
    </controller>
    <controller type='pci' index='4' model='pcie-root-port'>
      <target chassis='4' port='0x13'/>
      <alias name='pci.4'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x3'/>
    </controller>
    <controller type='pci' index='5' model='pcie-root-port'>
      <target chassis='5' port='0x14'/>
      <alias name='pci.5'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x4'/>
    </controller>
    <controller type='virtio-serial' index='0'>
      <alias name='virtio-serial0'/>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x00' function='0x0'/>
    </controller>
    <controller type='sata' index='0'>
      <alias name='ide'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/>
    </controller>
    <interface type='bridge'>
      <mac address='52:54:00:96:02:d6'/>
      <source bridge='br0'/>
      <target dev='vnet0'/>
      <model type='virtio'/>
      <alias name='net0'/>
      <address type='pci' domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
    </interface>
    <serial type='pty'>
      <source path='/dev/pts/0'/>
      <target type='isa-serial' port='0'>
        <model name='isa-serial'/>
      </target>
      <alias name='serial0'/>
    </serial>
    <console type='pty' tty='/dev/pts/0'>
      <target type='serial' port='0'/>
    </console>
    <channel type='unix'>
      <source mode='bind' path='/var/lib/libvirt/qemu/channel/target/domain-10-Windows 10/org.qemu.guest_agent.0'/>
      <target type='virtio' name='org.qemu.guest_agent.0' state='disconnected'/>
      <alias name='channel0'/>
      <address type='virtio-serial' controller='0' bus='0' port='1'/>
    </channel>
    <input type='tablet' bus='usb'>
      <alias name='input0'/>
      <address type='usb' bus='0' port='1'/>
    </input>
    <input type='mouse' bus='ps2'>
      <alias name='input1'/>
    </input>
    <input type='keyboard' bus='ps2'>
      <alias name='input2'/>
    </input>
    <hostdev mode='subsystem' type='pci' managed='yes'>
      <driver name='vfio'/>
      <source>
        <address domain='0x0000' bus='0x0a' slot='0x00' function='0x0'/>
      </source>
      <alias name='hostdev0'/>
      <address type='pci' domain='0x0000' bus='0x04' slot='0x00' function='0x0' multifunction='on'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x0a' slot='0x00' function='0x1'/>
      </source>
      <alias name='hostdev1'/>
      <address type='pci' domain='0x0000' bus='0x04' slot='0x00' function='0x1'/>
    </hostdev>
    <hostdev mode='subsystem' type='usb' managed='no'>
      <source>
        <vendor id='0x046d'/>
        <product id='0xc22a'/>
        <address bus='3' device='6'/>
      </source>
      <alias name='hostdev2'/>
      <address type='usb' bus='0' port='2'/>
    </hostdev>
      <source>
        <product id='0xc22b'/>
        <address bus='3' device='4'/>
      </source>
      <alias name='hostdev3'/>
      <address type='usb' bus='0' port='3'/>
    </hostdev>
      <source>
        <vendor id='0x25a7'/>
        <product id='0xfa23'/>
        <address bus='3' device='3'/>
      </source>
      <alias name='hostdev4'/>
      <address type='usb' bus='0' port='4'/>
    </hostdev>
    <memballoon model='none'/>
  </devices>
  <seclabel type='dynamic' model='dac' relabel='yes'>
    <label>+0:+100</label>
    <imagelabel>+0:+100</imagelabel>
  </seclabel>
</domain>
syslink:
default menu.c32
menu title Lime Technology, Inc.
prompt 0
timeout 50
label Unraid OS
  menu default
  kernel /bzimage
  append vfio-pci.ids=1002:67df,1002:aaf0 pcie_acs_override=downstream,multifunction initrd=/bzroot
label Unraid OS GUI Mode
  kernel /bzimage
  append pcie_acs_override=downstream,multifunction initrd=/bzroot,/bzroot-gui
label Unraid OS Safe Mode (no plugins, no GUI)
  kernel /bzimage
  append initrd=/bzroot unraidsafemode
label Unraid OS GUI Safe Mode (no plugins)
  kernel /bzimage
  append initrd=/bzroot,/bzroot-gui unraidsafemode
label Memtest86+
  kernel /memtest
Any help would be greately appriciated!
Thank you!
Hey @JDM_WAAAT I happened on this guide last night and it’s amazing so thank you for putting it together.
I have a question because I ran into a strange issue.
I got my VM up and running, drivers installed, sound working, everything recognised.
However when I booted it today I couldn’t connect with any VNC client from any of my devices. I checked my router and the machine wasn’t there, which made me think it has gotten stuck in some sort of boot issue.
I switched the VM back to using the built in VNC of unraid and I could get access to it and use it like usual no problem, and CPU usage was normal. But whenever I pass my GPU through this maxed out CPU + not booting starts again.
Here is my XML, screen shot and syslinux. If you can see anything in there which stands out to you I would greatly appreciate any help you have.
SYS
default menu.c32
prompt 0
timeout 50
label Unraid OS
  menu default
  kernel /bzimage
  append isolcpus=2-7,18-23 vfio-pci.ids=8086:105e,10ec:8168,1002:687f,1002:aaf8 isolcpus=2-7,18-23 pcie_acs_override=downstream,multifunction initrd=/bzroot
  kernel /bzimage
  append isolcpus=2-7,18-23 pcie_acs_override=downstream,multifunction initrd=/bzroot,/bzroot-gui
  kernel /bzimage
  kernel /bzimage
label Memtest86+
  kernel /memtest
XML
<domain type='kvm' id='2'>
  <name>Windows Game</name>
  <uuid>39345fb7-5e55-a28c-f149-3555111a1388</uuid>
  <description>Game</description>
  <metadata>
  </metadata>
  <memory unit='KiB'>16777216</memory>
  <currentMemory unit='KiB'>16777216</currentMemory>
  <memoryBacking>
    <nosharepages/>
  </memoryBacking>
  <cputune>
    <vcpupin vcpu='0' cpuset='2'/>
    <vcpupin vcpu='1' cpuset='18'/>
    <vcpupin vcpu='2' cpuset='3'/>
    <vcpupin vcpu='3' cpuset='19'/>
    <vcpupin vcpu='4' cpuset='4'/>
    <vcpupin vcpu='5' cpuset='20'/>
    <vcpupin vcpu='6' cpuset='5'/>
    <vcpupin vcpu='7' cpuset='21'/>
    <emulatorpin cpuset='7'/>
  </cputune>
  <resource>
  </resource>
  <os>
    <type arch='x86_64' machine='pc-i440fx-4.2'>hvm</type>
    <nvram>/etc/libvirt/qemu/nvram/39345fb7-5e55-a28c-f149-3555111a1388_VARS-pure-efi.fd</nvram>
  </os>
  <features>
    <acpi/>
    <apic/>
  </features>
  </cpu>
  </clock>
  <devices>
      <source file='/mnt/user/domains/Windows Game/vdisk1.img' index='2'/>
      <backingStore/>
      <boot order='1'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x05' function='0x0'/>
    </disk>
      <backingStore/>
      <readonly/>
    </disk>
      <alias name='sata0'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x0'/>
    </controller>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x04' function='0x0'/>
    </controller>
    <controller type='pci' index='0' model='pci-root'>
      <alias name='pci.0'/>
    </controller>
      <alias name='usb'/>
    </controller>
      <mac address='52:54:00:8f:69:c2'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0'/>
    </interface>
    <serial type='pty'>
      <source path='/dev/pts/1'/>
      </target>
    </serial>
    <console type='pty' tty='/dev/pts/1'>
    </console>
      <source mode='bind' path='/var/lib/libvirt/qemu/channel/target/domain-2-Windows Game/org.qemu.guest_agent.0'/>
    </channel>
    </input>
    </input>
    </input>
      <source>
        <address domain='0x0000' bus='0x48' slot='0x00' function='0x0'/>
      </source>
      <rom file='/mnt/user/isos/MSI.RXVega56.8176.171101.rom'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x06' function='0x0' multifunction='on'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x48' slot='0x00' function='0x1'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x08' function='0x0'/>
    </hostdev>
  </devices>
  </seclabel>
</domain>
Did you get this working as I am having the same issues and have the same graphics card as you. As soon as I switch to passing it through VM doesn’t boot properly as it’s not getting an IP.
Hello,
A good news I have now 9500 on passmark without stuttering.
I use 6 cores (all cores), what is important is emulator pin is used only by VM (last core), unraid use core 0, in addition first cores of VM is used only by VM.
I enabled Hyper-V, first try it didn’t work but, with this configuration it’s work:
<timer name='hpet' present='yes'/>
<timer name='hypervclock' present='yes'/>
<timer name='tsc' present='yes' mode='native'/>
I must set rtc, pit and hpet to avoid video driver error.
So my complete configuration:
<domain type='kvm' id='18'>
  <name>VM Gaming</name>
  <uuid>029de43a-30bb-3840-265f-99888582592b</uuid>
  <metadata>
  </metadata>
  <memory unit='KiB'>12582912</memory>
  <currentMemory unit='KiB'>12582912</currentMemory>
  <memoryBacking>
<nosharepages/>
  </memoryBacking>
  <vcpu placement='static'>6</vcpu>
  <cputune>
<vcpupin vcpu='0' cpuset='1'/>
<vcpupin vcpu='1' cpuset='2'/>
<vcpupin vcpu='3' cpuset='4'/>
<vcpupin vcpu='4' cpuset='0'/>
<vcpupin vcpu='5' cpuset='5'/>
<emulatorpin cpuset='5'/>
  </cputune>
  <resource>
  </resource>
  <os>
<nvram>/etc/libvirt/qemu/nvram/029de43a-30bb-3840-265f-99888582592b_VARS-pure-efi.fd</nvram>
  </os>
  <features>
<acpi/>
<apic/>
<hyperv>
  <relaxed state='on'/>
  <vapic state='on'/>
  <spinlocks state='on' retries='8191'/>
  <vpindex state='on'/>
  <synic state='on'/>
  <stimer state='on'/>
  <reset state='on'/>
  <vendor_id state='on' value='1234567890ab'/>
  <frequencies state='on'/>
</hyperv>
<kvm>
  <hidden state='on'/>
</kvm>
<vmport state='off'/>
<ioapic driver='kvm'/>
  </features>
<topology sockets='1' cores='6' threads='1'/>
  </cpu>
  </clock>
  <devices>
  <source file='/mnt/disks/ADATA_SX8200PNP_2K0220128518/VM Gaming/vdisk1.img' index='3'/>
  <backingStore/>
  <boot order='1'/>
</disk>
  <source file='/mnt/disks/ADATA_SX8200PNP_2K0220128518/VM Gaming/vdisk2.img' index='2'/>
  <backingStore/>
  <address type='pci' domain='0x0000' bus='0x00' slot='0x06' function='0x0'/>
</disk>
  <source file='/mnt/user/isos/Win10_2004_French_x64.iso' index='1'/>
  <backingStore/>
  <readonly/>
  <boot order='2'/>
</disk>
  <alias name='usb'/>
</controller>
</controller>
</controller>
</controller>
  <mac address='52:54:00:84:d2:2b'/>
</interface>
<serial type='pty'>
  </target>
</serial>
</console>
  <source mode='bind' path='/var/lib/libvirt/qemu/channel/target/domain-18-VM Gaming/org.qemu.guest_agent.0'/>
</channel>
</input>
</input>
</input>
  <source>
    <address domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
  </source>
</hostdev>
  <source>
    <address domain='0x0000' bus='0x01' slot='0x00' function='0x1'/>
  </source>
  <address type='pci' domain='0x0000' bus='0x00' slot='0x09' function='0x0'/>
</hostdev>
  </devices>
  </seclabel>
</domain>
I’d rather buy from a local reseller instead of Amazon, and I was just wondering if this product: https://www.digitec.ch/en/s1/product/logilink-hdmi-edid-emulator-digital-digital-video-converters-12949688 is the kind of dummy plug he mentioned throughout the tutorial? I don’t want to buy anything wrong of course.
No, it’s not.
