Hi Ian,
I was hoping to post the latest version of the parts list but it seems the forum is very finicky about links. I will figure something out when I have the time but for now, you might need to ctrl + F to find the links I’ve included in earlier posts…
So here is the minimally linked version of the post, this is my… third time trying to post.
I have been in touch with the seller of the fractal case and I missed out on that one
However, I have looking around a bit more and I have found the fractal case available for $189 ($124 USD) which does seem pretty expensive but talking with a friend who is a bit more home build savvy than I am pointed out that if you look for 8 bay cases on several Australian sites you will find them going for $50 to hundreds of dollars more. So I think in the interest of keeping things simple I will just purchase a new fractal case. Now that I know what I’m looking for I could maybe wait things out and find one online for a good price second hand but that could take months…
Now the RAM - I’ve looked at half a dozen sites and haven’t found anything that is really cheaper than that one from my last post.
So that said this is what I’m looking at at the moment:
CPU: Intel® Core™ i5-8500T Processor 9M Cache, up to 3.50 GHz SR3XD $73.50
MOTHERBOARD: Gigabyte GA-B360M-DS3H Motherboard 1151 Supports 9th Gen USB 3.1 DDR4 PCIe Gen3 $101.07
RAM: Patriot Viper Steel RGB DDR4 32GB (1 x 32GB) 3200MHz Module $87
HEATSINK: Thermalright Assassin Spirit 120 V2 CPU Air Cooler,4 Heat Pipes CPU Cooler, 120mm PWM Quiet Fan with 1500RPM, Desktop CPU Cooling, Computer Heatsink Cooler, for AMD:AM4/AM5&Intel 1700/1150/1151/1200 $27.90
STORAGE:
HDD STORAGE: 4 x WD Ultrastar HC550 16TB 3.5″ Enterprise SATA HDD WUH721816ALE6L4 Used $929 total for all 4
SSD STORAGE: Lexar NS100 1TB 2.5″ SATA III SSD LNS100-1TRB $89.99
CASE: Fractal Design Define R5 Black ATX Case, No PSU, USB 3.0 $189
PSU - POWER SUPPLY UNIT: HP Delta Electronics 475W Power Supply Unit PSU DPS-475CB 450937-001 452554-001 $35
USB FOR OS: SanDisk 64GB Cruzer Glide USB 3.0 Flash Drive SDCZ600-064G-B35 $8.92
OS: UNRAID
I’ve included bellow the table with the USD conversion.
Looking at it all it does seem to be a bit more than I was hoping to spend. Though its not beyond what I can afford.
