Hi all, thanks a lot for providing such a fantastic NAS killer guide. It helps me a lot.
I recently just built my first NAS with fractal design Node 804, supermicro x9scm-f and e3 1265L v2. But I found that iGPU is not detected in unraid:
IOMMU group 0: [8086:0158] 00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v2/Ivy Bridge DRAM Controller (rev 09)
IOMMU group 1: [8086:1502] 00:19.0 Ethernet controller: Intel Corporation 82579LM Gigabit Network Connection (Lewisville) (rev 05)
IOMMU group 2: [8086:1c2d] 00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 05)
Bus 001 Device 001 Port 1-0 ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002 Port 1-1 ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 003 Port 1-1.2 ID 0557:2221 ATEN International Co., Ltd Winbond Hermon
IOMMU group 3: [8086:1c10] 00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5)
IOMMU group 4: [8086:1c18] 00:1c.4 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 5 (rev b5)
IOMMU group 5: [8086:1c26] 00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 05)
Bus 002 Device 001 Port 2-0 ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002 Port 2-1 ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 003 Port 2-1.1 ID 0781:5591 SanDisk Corp. Ultra Flair
IOMMU group 6: [8086:244e] 00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a5)
[102b:0532] 03:03.0 VGA compatible controller: Matrox Electronics Systems Ltd. MGA G200eW WPCM450 (rev 0a)
IOMMU group 7: [8086:1c54] 00:1f.0 ISA bridge: Intel Corporation C204 Chipset LPC Controller (rev 05)
[8086:1c02] 00:1f.2 SATA controller: Intel Corporation 6 Series/C200 Series Chipset Family 6 port Desktop SATA AHCI Controller (rev 05)
[1:0:0:0] disk ATA CT500MX500SSD1 043 /dev/sdb 500GB
[3:0:0:0] disk ATA ST16000NM000J-2T SN02 /dev/sdc 16.0TB
[4:0:0:0] disk ATA ST16000NM000J-2T SN02 /dev/sdd 16.0TB
[8086:1c22] 00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 05)
IOMMU group 8: [8086:10d3] 02:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
After researching, I found in the mobo’s spec page: Supermicro | Products | Motherboards | Xeon® Boards | X9SCM-F,
- Intel E3-12x5 series processors which have integrated graphics support are not recommended.
I guess it’s the reason that the iGPU is not detected? I was wondering if anyone has working case with C202/C204 mobo and E3 12x5?
