2U Chenbro server with sliding rails, motherboard, PSU, and more…
LGA 1151 motherboard - BCM BC370Q
Supports 8th/9th gen Intel CPUs (only certain 9th gen)
2 x Intel GbE NIC
1 x M.2 NVMe/SATA
800W PSU w/ dual 8-pin PCIe power
2 x hotswap 2.5" bays
2 x static 2.5" bays
1 x static 3.5" bay
2 x 80mm fans
1 x 60mm CPU cooler
Full height riser card with 2-3 expansion slots (can’t tell from pic)
Chenbro cassis specs
Mine came in nearly brand new condition well packaged.
Basically: add CPU, RAM, and some sort of storage, and you’re good to go. I’m converting my HP 290 boxes into these.
Seller is asking $149 + $25 shipping OBO
Seller is accepting $125 as best offer. Mention you are from serverbuids.net in the note!
dhole
May 18, 2020, 6:40am
2
Received mine, adding a bunch of pics so people can see what they have, extra call-out to the IcyDock that it comes with and the dual riser giving you access to two addon cards. Will be doing a QS build using parts transplanted from an HP290
ajp
May 21, 2020, 1:58am
4
Wow, wish I had seen this when it was posted. I’ve been wanting a rackmount quicksync solution other than SuperMicro’s $500 kit.
FWIW the HP290 rackmounts decently well, it’s a touch over 2U on its side, and it’s shallow enough that you can put two on a full length shelf.
ajp
May 26, 2020, 4:16pm
6
That’s true. I’d prefer a rackmount chassis if I can. If you decide to sell one of yours you bought, I’m interested
