I want to replace my old NAS that I’m using now, wich is basically my old “main” PC that runs Windows 10 on it and then I share the harddrives to my new
main PC and my Nvida shield. It’s going to be most of the time one user at the time.
No transcoding with Plex
I want to make a new build beacuse the old system has run 24/7 for the last ten years, could not get ubuntu server to install no matter what I did. It’s not that I can’t get the installation process going,
but it always end with some sort of error code. I’m not a total noob and I’m not an expert but it’s so frustrating to sit there for a day trying different things, googeling, try again and still don’t get it to work.
Maybe I could get it to work by installing a realy old version of Ubuntu server, but I still end up with a system that is on its last legs.
I also have problem with that system when it’s time to upgrade W10 to a newer version, has to try it like ten times before it succeeds.
I have built a couple of computers before. I have used a Raspberry Pi with an external HDD before as a “server”, superslow.
I have looked at your NAS Killer 4.1 thread and about that, I live in Europa so it’s a little more difficult to find those components you are listing and about the prize, it’s not that big of a different.
I also want it to be a little smaler in size and
don’t have to use one of the sata ports for a SSD disk to install OS.
I’m not going to have Unraid as OS, that is beacuse I’m going to run a torrent client plus VPN (mullvad) on it. So therfore I’m going with Ubuntu server with a
desktop enviroment. I have seen that some people can get torrent client with VPN to run on Unraid, maybe I will give it a try.
Basically I have looked at this build in this forum and that looks appealing to me:
What I am thinking is:
| Part: | Name: | ||||||||||||||||||||||||
| Case: | Fractal Design Node 804 | Amazon.com: Fractal Design Node 804 No Power Supply MicroATX Cube Case FD-CA-NODE-804-BL, Black : Electronics | |||||||||||||||||||||||
| Motherboard: | ASUS PRIME B450M-K II | Amazon.com | |||||||||||||||||||||||
| SSD: | Kingston 250GB A2000 M.2 | Amazon.com | |||||||||||||||||||||||
| PSU: | Seasonic FOCUS GX-650, 650W 80+ Gold | Amazon.com | |||||||||||||||||||||||
| RAM: | Corsair Vengeance LPX DDR4 2400MHz 2x8GB (CMK16GX4M2Z2400C16) | Amazon.com | |||||||||||||||||||||||
| CPU: | AMD Athlon 3000G | Amazon.com | |||||||||||||||||||||||
| CPU Cooler: | Cooler Master Hyper 212 EVO V2 | Amazon.com | |||||||||||||||||||||||
| HDD: | WD Red |
CPU: maybe a AMD Athlon 200GE, AMD Athlon 220GE or even a AMD Ryzen 3 3200G
PSU: maybe a 550 w instead
RAM: not that big of a differnet in prize between this and a realy cheap ones and I just picked one that was in the “Memory QVL for AMD Ryzen™ & Athlon™ with Radeon™ Vega Graphics Processors” list for this motherboard
HDD: I have three WD red, but I will buy one extra and put the old ones in this build to.
