WD 10TB Elements - WDBWLG0100HBK-NESN - $160
Are these drives suitable for a NAS application?
Yep. Shuckable for internal use. No questions asked buy at this price.
Bestbuy also has the 8TB Easystore for $130, which is about the same price/capacity. I would rather get these since it is available for store pickup. Are the internal drives similar?
Don’t forget, drive bays are expensive. I would get the 10TB.
It doesn’t matter whether it’s in store or online IMO.
Gutted this isn’t available in the UK. Currently £253…
I ordered two of them, thanks for the link.
its 135€ in austria (is you have prime, you can currently get prime for 1 week for 99cents)
This are good too, looks like you can get the 10TB for just 20 more euro, which is a better price per TB.
