Good day, I have been having issues getting my W10 VM to display. Sometimes it will load up and it is usable, more often than not though, it will not display, the monitor appears as though there is no signal.
Please let me know what other logs you want/need.
-display none
-no-user-config
-nodefaults
-chardev socket,id=charmonitor,fd=33,server,nowait
-mon chardev=charmonitor,id=monitor,mode=control
-rtc base=localtime
-no-hpet
-no-shutdown
-boot strict=on
-device ich9-usb-ehci1,id=usb,bus=pci.0,addr=0x7.0x7
-device ich9-usb-uhci1,masterbus=usb.0,firstport=0,bus=pci.0,multifunction=on,addr=0x7
-device ich9-usb-uhci2,masterbus=usb.0,firstport=2,bus=pci.0,addr=0x7.0x1
-device ich9-usb-uhci3,masterbus=usb.0,firstport=4,bus=pci.0,addr=0x7.0x2
-device virtio-serial-pci,id=virtio-serial0,bus=pci.0,addr=0x3
-blockdev ‘{“driver”:“file”,“filename”:“/mnt/user/domains/Windows 10/vdisk1.img”,“node-name”:“libvirt-3-storage”,“cache”:{“direct”:false,“no-flush”:false},“auto-read-only”:true,“discard”:“unmap”}’
-blockdev ‘{“node-name”:“libvirt-3-format”,“read-only”:false,“cache”:{“direct”:false,“no-flush”:false},“driver”:“raw”,“file”:“libvirt-3-storage”}’
-device virtio-blk-pci,scsi=off,bus=pci.0,addr=0x4,drive=libvirt-3-format,id=virtio-disk2,bootindex=1,write-cache=on
-blockdev ‘{“driver”:“file”,“filename”:“/mnt/user/isos/Windows.10.iso”,“node-name”:“libvirt-2-storage”,“auto-read-only”:true,“discard”:“unmap”}’
-blockdev ‘{“node-name”:“libvirt-2-format”,“read-only”:true,“driver”:“raw”,“file”:“libvirt-2-storage”}’
-device ide-cd,bus=ide.0,unit=0,drive=libvirt-2-format,id=ide0-0-0,bootindex=2
-blockdev ‘{“driver”:“file”,“filename”:“/mnt/user/isos/virtio-win-0.1.160-1.iso”,“node-name”:“libvirt-1-storage”,“auto-read-only”:true,“discard”:“unmap”}’
-blockdev ‘{“node-name”:“libvirt-1-format”,“read-only”:true,“driver”:“raw”,“file”:“libvirt-1-storage”}’
-device ide-cd,bus=ide.0,unit=1,drive=libvirt-1-format,id=ide0-0-1
-netdev tap,fd=35,id=hostnet0,vhost=on,vhostfd=36
-device virtio-net-pci,netdev=hostnet0,id=net0,mac=52:54:00:c3:06:b6,bus=pci.0,addr=0x2
-chardev pty,id=charserial0
-device isa-serial,chardev=charserial0,id=serial0
-chardev socket,id=charchannel0,fd=37,server,nowait
-device virtserialport,bus=virtio-serial0.0,nr=1,chardev=charchannel0,id=channel0,name=org.qemu.guest_agent.0
-device usb-tablet,id=input0,bus=usb.0,port=1
-device vfio-pci,host=0000:01:00.0,id=hostdev0,bus=pci.0,addr=0x5
-device vfio-pci,host=0000:01:00.1,id=hostdev1,bus=pci.0,addr=0x6
-device vfio-pci,host=0000:00:1b.0,id=hostdev2,bus=pci.0,addr=0x8
-device usb-host,hostbus=3,hostaddr=10,id=hostdev3,bus=usb.0,port=2
-device usb-host,hostbus=3,hostaddr=11,id=hostdev4,bus=usb.0,port=3
-sandbox on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny
-msg timestamp=on
2020-04-12 18:51:39.731+0000: Domain id=14 is tainted: high-privileges
2020-04-12 18:51:39.731+0000: Domain id=14 is tainted: host-cpu
char device redirected to /dev/pts/0 (label charserial0)
