Ive been thinking about building a new machine dedicated to VMs and for me learn Cloud stuff and to start building a home lab. I can get by without doing all of this, but whats the fun in that? I’ve been looking at some motherboards and CPUs and wanted to get opinions on my choices and to make sure everything will work together. This is what ive been looking at:
Supermicro Dual Intel Socket LGA2011 Rev 1.20 System Board with I/O Plate
- Form Factor: Enhanced Extended ATX
- Processor Compatibility: Supports E5-2600/ E5-2600 v2 series
- Chipset: Intel C602 chipset
- Expansion Slots: 4 (x16) PCI-E 3.0 slots; 1 (x8) PCI-E 3.0 slot; 1 (x4) PCI-E 3.0 (in x8) slot
- Memory Compatibility: 24x 240-pin DDR3 DIMM slots; 1866/1600/1333/1066/800MHz ECC DDR3 SDRAM 72-bit, 240-pin gold-plated DIMMs; support ECC and non-ECC UDIMMs
- Network Ports: 4x Gigapit Ethernet LAN ports; Intel i350 GbE controller
With these CPUs:
Intel Xeon E5-2670 v3 2.3GHz 30MB 12-Core 120W LGA2011-3 SR1XS
I’m not set with this but I would like something that would have enough power to do VMs in a home environment.
Any opinions on this combo or can you recommend something that would be better? I’d rather spend the money now with something that would suit me for a while, than to find out its under powered and I would have to build something else.
Here’s link to what I was looking at
