Ships from WA USA
Asking $200/ea for the Tripp Lites and $100 for the Chatsworth CPI.
Currently have (2) Tripp Lite vertical mount 6’ PDU and (1) CPI horizontal rack mount PDU. One vertical and the horizontal PDUs were used for a crypto system the other has never been used still in plastic wrap but no original packaging or contents. PDUs ONLY no accessories. Asking price includes shipping.
1.9kW Single-Phase Monitored PDU, 120V Outlets (24 5-15/20R), L5-20P/5-20P Adapter, 0U Vertical, 70 in
MFR: Tripp Lite
Model: PDUMNV20 ($200/ea)
Features
- 120V Monitored PDU with built-in network interface in 0U 70 in. / 178cm rackmount form factor; 20A maximum capacity (agency de-rated to 16A)
- Attached 10 ft. / 3m NEMA L5-20P input cable with NEMA 5-20P adapter included
- 24 NEMA 5-15/20R outlets
- 0U 70 in. / 178cm vertical rackmount form factor
- Network interface provides PDU control and data regarding input voltage, frequency and loading information
- Digital display reports load level information in amps
- Supports user-specified alarm notification thresholds
- In-rack environmental reporting with optional ENVIROSENSE temperature / humidity sensor and rack access notification with up to 4 optional SRSWITCH door sensors
- DHCP/Manual configuration support
- 10/100 Mbps auto-sensing
- Real-time clock backup maintains the time of day and date even if the PDU is unpowered
- Tiered access privileges allow an administrator and a guest to login simultaneously
- Alert notifications via email or SNMP traps offer immediate event notification
- Firmware upgrade ability supports future product enhancements
- Supports HTTP, HTTPS, PowerAlert Network Management System, SMTP, SNMPv1, SNMPv2, SNMPv3, Telnet, SSH, FTP, DHCP, BOOTP, NTP protocols
- Fully compatible with FREE PowerAlert Network Management System / NMS Software
- Included cord retention brackets
- Toolless mounting supported in button-mount compatible racks, plus nut-and-bolt mounting brackets for other mounting applications
- Federal Trade Agreements Act / TAA Compliant for GSA Schedule purchases
Chatsworth 12816-707 Surge-Protected; 20 Amp; 1.9 kW; NEMA 5-20P; 1 x 20A Breaker; (6) 5-20R Outlets; 1U; Black
MFR: Chatsworth
PN: 12816-707
|Volts:|110-125V|
|Plug:|NEMA 5-20P|
|Phase:|Single-Phase, Surge Protected|
|Outlets:|(6) 5-20R Standard Outlets|
|AMP:|20A|
