I did some consolidating in my server closet last month, and now I have a bunch of gently used server components for sale. This list is just a start, I’ll be adding additional items as I test them and take pictures. All items have been tested and verified working just prior to being listed. Free shipping is via whatever method is cheapest for me. Payments via PayPal or Venmo preferred. Items marked as pending are sold and waiting for payment. Once items are sold and paid for, I’ll move them to the bottom of the post.
Sold Items
SuperMicro X9DR3-LN4F+
- SuperMicro X9DR3-LN4F+ with dual Xeon E5-2670 v1 CPUs, Active Heatsinks with Noctua fans, IO Shield and 192GB RAM -
$350 ShippedSOLD- The X9DR3-LN4F+ board features an Intel C606 chipset, four Intel gigabit LAN ports (Intel i530 controller), 2x SATA3 (6Gbps) ports, 4x SATA2 (3Gbps) ports, and onboard IPMI
- 24 RAM Slots
- 1 Internal USB 2.0 port
- Size EE-ATX 13.68" x 13" Note the large size, please measure your chassis for fit before purchasing
- Board has been updated to the latest BIOS image and IPMI firmware
- Full specs here: SuperMicro X9DR3-LN4F+
- The Xeon E5-2670 has a base frequency of 2.60 GHz, 8 cores, 16 threads, and 20MB of cache
- Full specs here: Intel ARK E5-2670
- This combo includes 24x Samsung 8GB 2Rx4 PC3L-10600R DIMMs for a total of 192GB
LSI 9205-8i SAS Controller
- LSI 9205-8i SAS Controller -
$30 ShippedSOLD- SAS2308 Chipset
- 4Kn support
- PCI-E 3.0 x8 Interface
- Controller is flashed into P20 IT mode
Mellanox 10Gig NIC Combo
- Mellanox MNPA19-XTR Connectx-2 10Gig NIC 2-Pack With 3M DAC cable
$60 ShippedSOLD- Includes both full-height and low-profile brackets for both cards
M.2 NVME Adapter
- M.2 NVME To PCI-E Adapter
$5 Shipped2 SOLD- Convert a 2230, 2242, 2260, or 2280 sized M.2 NVME drive to a standard PCI-E slot
- Fits in x4, x8, or x16 PCI-E slots
LSI 9211-8i SAS Controller
- LSI 9211-8i SAS Controller -
$25 Shipped2 SOLD- SAS2008 Chipset
- PCI-E 2.0 x8 Interface
SuperMicro LGA2011 Active Heatsink 2-Pack
- SuperMicro SNK-P0050AP4 Socket LGA2011 4U Active Heatsink 2-Pack -
$55 ShippedSOLD- Comes with both the square and narrow ILM brackets
- Upgrade with Noctua NF-B9 PWM Fans
- These heatsinks have been used
- You get two fans for this price
DFI DT122-BE Industrial Desktop
- DFI DT122-BE with 16GB DDR3 RAM and a 60GB mSATA SSD -
$160 ShippedSOLD- AMD RX-472BB Embedded CPU
- 2x 8GB PC3-12800s 1600MHz DDR3 SODIMMs
- 1x 60GB Sunbow mSATA SSD
- Upgraded Fractal CPU and Exhaust fans for quiet operation
- Full system specs available here: DFI DT122-BE
- System comes completely assembled and tested
SuperMicro X8DTH-6F
- SuperMicro X8DTH-6F with dual Xeon L5640 CPUs, Heatsinks, IO Shield, and 40/48GB RAM -
$200 ShippedSOLD- The X8DTH-6F board features the Intel 5520 chipset, dual Intel gigabit LAN, an integrated Broadcom SAS2008 SAS Controller, 6x SATA2 (3Gbps) ports and onboard IPMI
- 12 RAM Slots
- Size E-ATX 12" x 13"
- Integrated SAS Controller has been flashed with P20 IT mode firmware
- Full specs here: SuperMicro X8DTH-6F
- The Xeon L5640 has a base frequency of 2.26 GHz, and features 6 cores, 12 threads, and 12MB of cache
- Low power Xeon with a TDP of 60 Watts
- Full specs here: Intel ARK L5640
- This combo includes 12x Micron 4GB 2Rx4 PC3-10600R DIMMs for a total of 48GB
- Upgrade to either of the 1366-compatible active heatsinks listed below and take $10 off the combo
SuperMicro X8DT3-LN4F
- SuperMicro X8DT3-LN4F with dual Xeon E5630 CPUs, Heatsinks, IO Shield, and 8GB RAM -
$125 ShippedSOLD- The X8DT3-LN4F board features the Intel 5520 chipset, four Intel gigabit LAN ports, 6x SATA2 (3Gbps) ports and onboard IPMI
- 12 RAM Slots
- 2 internal USB 2.0 ports
- Size: E-ATX 12" x 13"
- Full specs here: SuperMicro X8DT3-LN4F
- The Xeon E5630 has a base frequency of 2.53 GHz, 4 cores, 8 threads, and 12MB of cache
- Full specs here: Intel ARK E5630
- This combo includes 2x Hynix 4GB 2Rx8 PC3-10600R DIMMS for a total of 8GB
SuperMicro Drive Tray
- SuperMicro MCP-220-84603-0N Fixed HDD Tray -
**4 Available, $15 Shipped For 1, $28 For Two, $40 for Three, Or Buy All Four for $50SOLD- Adds a single 3.5" or dual 2.5" drive bays to the interior of your SuperMicro SC846 chassis
- Brackets are like new, with all screws and grommets included
SuperMicro LGA1366 Active Heatsink 2-Pack
- SuperMicro SNK-P0036A4 Socket LGA1366 2U Active Heatsink 2-Pack -
$45 ShippedSOLD- These fans are brand new in box
Arctic Freezer 12 Active Heatsink 2-Pack
- Arctic Freezer 12 4U Tower Heatsink 2-Pack -
$32 ShippedSOLD- Officially compatible with Intel 115x, 2066, and 2011 (Square only), and AMD AM4 sockets
- Also unofficially compatible with Intel 1366 socket when you use the 115x screws in the 2011 mounting holes
- Does NOT include the cooler backplate or thermal compound
Noctua Fan Accessories
Each kit is $2, with a flat $3 shipping for the order, or free shipping if you purchase any of the other items I’m selling. ALL SOLD
Noctua 4-Pin Fan Accessory Kit - SOLD
- Each Kit includes the following:
- 1x NA-RC7 Low-Noise Adapter
- 1x NA-YC1 Y-Cable
- 1x NA-EC1 30cm Extension Cable
- 4x Anti-Vibration Mount
Noctua 3-Pin Fan Accessory Kit - SOLD
- Each kit includes the following:
- 1x NA-RC11 Low-Noise Adapter
- 1x NA-EC2 Extension Cable
- 1x NA-AC2 3-2 Pin Adapter
- 1x NA-JC1 OmniJoin Adapter Set
Noctua Miscellaneous Accessories - SOLD
- All the remaining parts left-over after assembling the kits above, plus some loose grommets
- 5x NA-RC7 Low-Noise Adapters
- 1x NA-YC1 Y-Cable
- 2x NA-EC1 30cm Extension Cable
- 8x Noctua Grommets
Changelog:
05-Feb-2020 - Formatting updated, moved sold items to the bottom, updated pricing on some items
07-Feb-2020 - Moved additional sold items to bottom
09-Feb-2020 - Added additional items
22-Feb-2020 - More New Items
24-Feb-2020 - Moved sold items
24-Apr-2020 - Remaining items sold, closed post
