It is official, I am moving and need to clear out some gear to cut down on the moving bill. All prices below are OBO (more likely to give good deals to bulk orders).
With the exception of the JBODs/Servers, free shipping on all orders >= $100. For orders less than $100, I expect shipping to run $4-$10. For JBODs/Servers I will split shipping costs with the buyer. Free local pickup near Boulder, CO (80503); if you are picking up locally I will probably toss in some free gear.
If you are interested in any of these items please send me a PM with your Paypal address and your shipping zip code, and I will send you a Paypal invoice.
SuperMicro AOC-STGN-I2S Dual Port SFP+ 10Gb NIC
- Qty Available - 30
- Price - $40/each
- Form factor - Low Profile and half length card
- Intel 82599ES 10GbE controller
ProLabs SFP-H10GB-CU 3 & 5 Meter 10Gb DACs
- Qty Available - 50+
- Price - 3M = $10/each & 5M = $15/each
- Colors available - Red & Blue
- These are brand new in sealed retail packaging. Should be compatible with anything the Cisco cables are (e.g. should work fine with Ubiquity Gear)
1.2TB 2.5" SAS 10K Hard Drives
- Qty Available - 200
- Price - $20/each
- Model Numbers: HGST HUC101212CSS600 & Seagate ST1200MM0088
- HGST drives have about 6 years POH while the Seagate are ~2 years
- Drives were formally formatted 520 however I have formatted them to 512 to maximize compatibility
4TB 3.5" SATA 5400RPM WD Purple
- Price - $35/each
- Model Numbers: WD40PURZ & WD40PURX
- Drives have POH ranging from 0-3 years of usage; no bad sectors
EMC KTN-STL3 15 Bay 3U JBOD
- Price - $75/each
- Redundant PSUs and Controllers
- Shipping - Will ship securely in custom box + Instapak; cost (after splitting) should be $20-$40 depending on where you are located
- Note - These do not include the caddies, but do include 15x 303-115-003D interposers (compatible with both SAS and SATA drives); you can either shim in the HDDs with some cardboard or print your own caddies
EMC VRA60 60 Bay 4U JBOD
- Qty Available - 5
- Price - $650/each
- Shipping - These will likely need to go freight shipping. Reach out for a quote.
- 3x of these have the full 60 caddies, 1x has 26x caddies (plus blanks), 1x has no caddies and full of blanks
SuperMicro CSE-937 16 Bay 3U JBOD
- Qty Available - 8
- Price - $150/each
- Shipping - Not sure if these would make more sense via freight vs ground
- Note - No caddies are included; no interposers required, you can shim in the drives, print your own, or pick some up cheap off eBay.
Dell PowerEdge R740
- Qty Available - 2
- Price - $4,500/each
- Form Factor - SFF 16x2.5"
- 2x Platinum 8168 CPUs (48 Cores / 96 Threads total)
- 256GB DDR4 RAM (8x32GB 2666Mhz)
- 2x10Gb (SFP+) & 2x1Gb Network Daughter card (Dell P/N 6VDPG, X710/i350 chipsets)
- 2x1100W Platnium PSUs
- iDRAC enterprise
- Bezel included
- Ships in original packaging
Dell PowerEdge R640
- Qty Available - 1
- Price - $1,500
- Form Factor - Diskless configuration
- 2x Gold 5122 CPUs
- 128GB DDR4 2666Mhz
- 4x1Gb NIC
- 2x750W Platnium PSUs
- iDRAC express
Dell Precision T5820
- Qty Available - 1
- Price - $400
- Form Factor - 4x3.5" Bay (top two bays are NVMe, bottom two bays are SATA)
- Xeon W-2123 CPU (4 Cores / 8 Threads)
- 16GB DDR4 RAM (1x16GB 2666Mhz)
- No GPU (see below for add-ons)
- 950W PSU
Add-ons (might be willing to sell some of these individually)
- Quadro P5000 - $350
- Quadro M5000 - $150
- RTX 3090 (Dell OEM) - $750
- RTX 3080 (Dell OEM) - $475
- 32GB 2666Mhz DDR4 DIMM - $65
- NVMe Flex Bay - $100
DDR3 ECC RDIMMs
- 16GB 12800 - $10/DIMM
- 16GB 10800 - $8/DIMM
- 8GB 12800 - $4/DIMM
- 8GB 10800 - $3/DIMM
- 4GB 10800 - $1/DIMM
SanDisk ioMemory PX600 5.2TB PCIe SSD
- Qty Available - 8
- Price - $400/each
- These things are tanks in terms of endurance (64 Petabytes) and also sport some pretty impressive IOPS and throughput
- Note depending on your setup these might not be plug and play - For Ubuntu I needed to compile my own drivers (GitHub - RemixVSL/iomemory-vsl4: Updated Fusion-io iomemory VSL4 Linux (version 4.3.7) driver for recent kernels.); on Windows there are some OEM installers that worked for me (https://dell-support.sandisk.com/)
Lenovo x3650 M5 Barebone (very similar to R730xd LFF)
- Price - $400/each
- Qty Available: 6 (limited
- Form Factor: 2U with 12x3.5" HDD bays
- CPUs: None included, 2x LGA2011-3 (Xeon E5-26xx v3/v4), heatinks included
- RAM: None included 24x DDR4
- PSUs: 2x 900W
- NIC: 4x1Gb onboard
- RAID: LSI SAS 9302-8i N2215
- HDDs: None included, 12x trays included
- IPMI: Integrated Management Module II w/ license (similar to iDRAC)
- Options: 2x3.5" Rear backplane (only a few of these available) +$50
Note - I can build these out to your desired specifications - Have a decent selection of CPUs and a lot of RAM on hand.
