I currently have
Chenbro NR12000 1U
and I believe it has died. It has been shutting down by itself daily but up until today I was able to reboot it. Today it sounds like it reboots but the VGA connected monitor is not getting a signal and I can’t connect to unraid’s web ui. Also can’t get in the bios. No video shows up at all.
I will pull one of the ram sticks and see if it will boot up. I don’t know if there is anything else I can do.
Edit- I opened the case to remove the ram and replace the 2032 battery and there is a solid red light next to the cpu.
My main question is can I upgrade the motherboard/ram/cpu to keep using the chassis? If not is there a case and motherboard that will give me 12 sata connections?
Current specs (I don’t need Plex transcoding. I have a Shield for that)
Intel® Xeon® CPU E3-1230 V2 @ 3.30GHz
32Gb Ram DDR3 Single-bit ECC
12 drive capacity
60TB
6 Data drives
1 Parity
500 Gb Cache SSD
And run
Adguard
krusader
Guacamole
Firefox
Cloudflare DDNS
Home Assistant
jackett
Nginx
NodeRed
radarr
resilio
shinobi
sonarr
unifi-controller
