I have built a couple of PCs and I feel confident doing so, but when it comes to building a media server/NAS I feel lost.
What I have
Today I stream movies and tv-shows from my desktop PC using Emby server, to my LG TV with the Emby app and simultaneously to one or two android tablets, both with the Emby app installed. All streams need to be able to have subtitles activated (I guess this is transcoding?). Usually 1080p is good enough for me, file format I mostly use are mp4, h264, h265 and mkv.
This works great at the moment since my desktop has an i9-9900K with 32GB RAM.
I’m using sabNZB.
I also have an old Synology DS412+ as a file server, mostly family photos and backup of cell phones.
What I want
Priority 1: A stand alone media server that can do the same thing that I am doing on my desktop PC today, but hopefully more energy effective, and in a smaller case.
Priority 2: Also use the media server as a NAS so that I can retire the Synology.
The media server/NAS needs to be accessed remotely on my network – I will not have a monitor/keyboard/mouse connected to it after its initial installation. OS – I am open to suggestions! Unraid, TrueNAS, Windows (I guess not), Ubuntu?
I have a Cooler Master NR200P case that I can use. I also have a 1070 ti if necessary, although I am guessing that I will be ok with a CPU with integrated graphics?
So, I need help.
Can I run a NAS and a Media server on the same machine? What kind of CPU do I need? – I am looking at an Intel for Quick Sync. But which one is good enough?
Motherboard will be an mITX that works with the CPU of course.
Storage and RAM I can figure out.
The current value sweet spot for a media server is an 8th or 9th gen Intel Core i3 or potentially a Core i5 if you want a little more headroom to run additional services and you can find a good deal on one.
For the OS I would recommend Unraid It is designed from the ground up to be a media server / NAS and has a very user friendly interface for managing it all as well as large community of users so there are plenty of resources out there for learning it.
Nope, for transcoding you will want to use the Intel iGPU.
The Nvida card is much more powerful in terms of 3D acceleration, but for video transcoding the Intel Quick Sync Video accelerator is better than anything else.
Looking to finally build my own mediaserver and light storage NAS, I read this response from a year ago: The current value sweet spot for a media server is an 8th or 9th gen Intel Core i3 or potentially a Core i5 if you want a little more headroom to run additional services and you can find a good deal on one. does the same ring true today?
Would an advance to generation 10, 11 or 12 i3/5 be warranted?
Hi @N3xus,
I came across your post while investigating transcoding/iGPU capabilities of my Xpenology server which I’m running configured as a Synology DS3622xs+ with DSM 7.2.2-72806 Update 3. My system comprises ASUS Pro WS W680-ACE IPMI motherboard, an Intel i7-14700K CPU (with iGPU), 64 GB ECC DDR5 RAM, in a Fractal Design Define 7 XL case with 16 port LSI 9308 with 16 x 16TB Seagate Exos X16 SATA drives giving 2 x 83.77TB volumes of 8 drives each, both in SHR2 config.
The CPU has integrated HDR770 graphics and I am not experiencing any difficulties using the system to serve a few Plex clients as well as to support external access to my Synology Photos application and photos/videos.
Most of my Plex usage comprises h264, h265 and mkv.
I initially experienced considerable difficulties with the system due to problems with PSU and the IPMI card. Since replacing the PSU and rectifying the faulty IPMI cabling (ASUS completely wiped me of any support with the IPMI because I purchased it from US (I’m in Australia); the system is now operating reliably, giving me great satisfaction. I’m running continuous deduplication across each volume.
System does not appear to be a heavy power user, idling along most of the time with cpu running at 2% and memory 8% with only 1 Plex client.
I should note that I went with the ASUS W680-ACE motherboard and the i7-14700K cpu to get the iGPU and ECC memory as protection against bitrot. Whether my paranoia is justified, or not, I’m happy with my decision and keen to subject it to any stress tests to validate the suitability of the platform as a media server.
