Tenda 8 Port Gigabit Ethernet Network Switch | Ethernet Splitter | Plug-and-Play | Traffic Optimization | Unmanaged (SG108), Black
| Brand | Tenda |
| Material | ABS |
| Item Dimensions LxWxH | 3.54 x 0.94 x 5.59 inches |
| Mounting Type | Wall Mount |
| Actuator Type | Push Button |
| Mechanical Life Expectancy | 3 years |
About this item
- PLUG-AND-PLAY - Easy setup with no configuration or no software needed
- Nice&Small - 1429024mm( LWH),also can be a home ornament.
- ETHERNET SPLITTER - Connectivity to your router or modem for additional wired connections (laptop, gaming console, printer, etc)
- 8 Port GIGABIT ETHERNET - 8 10/100/1000 Mbps Gigabit auto-negotiation RJ45 ports greatly expand network capacity,Support Auto MDI/MDIX
- RELIABLE - IEEE 802.3x flow control provides reliable data transfer
- AUTO-NEGOTIATION - Supports Auto-MDI/MDIX, eliminating the need for crossover cables
- Note: Kindly refer the installation manual before use.
$15.29
>>> LINK <<<
- Good Deal
- Mediocre Deal
- Bad Deal
0
voters
