HOW TO INSTALL AND USE STEAMCMD
This is a brief tutorial on the basics of installation and usage of SteamCMD.
NOTE: LINUX USERS CAN USE: https://linuxgsm.com/ TO MAKE IT EASIER FOR YOU
Windows
- Create a folder for SteamCMD.
C:/steamcmd
- Download the SteamCMD (Windows) Update Tool.
- Extract the contents of the zip to the folder.
Linux
- Create a user for SteamCMD and login.
Note: For security best practice, do not run SteamCMD a root.
adduser steam
su - steam
- Create a directory for SteamCMD.
mkdir /home/steam/steamcmd
cd /home/steam/steamcmd
- Download the SteamCMD (Linux) Update Tool.
wget http://media.steampowered.com/installer/steamcmd_linux.tar.gz
- Extract the contents to the directory.
tar -xvzf steamcmd_linux.tar.gz
Running SteamCMD
Windows
Browse to the SteamCMD folder and click on steamcmd.exe.
Alternatively Open a Command Prompt to start SteamCMD.
cd C:\steamcmd
steamcmd
Linux
Open a terminal and start SteamCMD.
./steamcmd.sh
Available Commands
Type help for more information on the available commands.
help
Login to SteamCMD
To download most game servers, you can log in anonymously.
login anonymous
Some servers require you to login with a Steam Account. To find out if your server requires a login see Dedicated Servers List.
Note: For security reasons, it is recommended that you create a new Steam username just for SteamCMD.
Note: A user can only be logged in once at any time.
login username
Next, enter your password.
If Steam Guard is activated on the user account check your e-mail for a Steam Guard access code and enter it. This is required first time only.
You should see a message stating that you have successfully logged in with your account.
Installing a Server
- Start SteamCMD and set your app install directory.
force_install_dir
- Windows
force_install_dir c:\steamcmd\csgoserver
- Linux
force_install_dir /home/steam/csgoserver
- Install the app by using a Steam Application ID or <app_id>. To also validate the app add validate to the command. To participate in HLDS beta testing add -beta beta to the command. To participate in SRCDS beta testing add -beta prerelease to the command.
app_update validate
Example for Counter Strike: Global Offensive
app_update 740 validate
Example for Team Fortress Classic
app_set_config 90 mod tfc app_update 90 validate
Automating SteamCMD
SteamCMD can be automated to run tasks directly from the command line/terminal. This is very useful for running your own scripts.
Windows
steamcmd +login anonymous +force_install_dir c:\steamcmd\csgoserver +app_update 740 validate +quit
Linux
./steamcmd.sh +login anonymous +force_install_dir /home/steam/csgoserver +app_update 740 validate +quit
Example for Counter Strike: Condition Zero
Windows
steamcmd +login anonymous +force_install_dir c:\steamcmd\csczserver +app_set_config 90 mod czero +app_update 90 validate +quit
Linux
./steamcmd.sh +login anonymous +force_install_dir /home/steam/csczserver +app_set_config 90 mod czero +app_update 90 validate +quit
Example for Killing Floor
Windows
steamcmd +login +force_install_dir c:\steamcmd\kfserver +app_update 215350 validate +quit
Linux
./steamcmd.sh +login +force_install_dir /home/steam/kfserver +app_update 215360 validate +quit
References:
https://danielgibbs.co.uk/2014/02/steamcmd/
IPTables Coverage:
