Guys I’m here for your opinion. I like my current homelab
Which looks like this:
-iGel thin client with pfsense on it
-Aruba S1500 48 PoE MAS
-Optiplex 9020 with the media crap on Truenas Scale
-Aruba AP 205 i think
It has been a great learning opportunity for me with firewalls , vlans , and so on, but I don’t think I’m where I want to be?. I setup Pfsense with 3 Vlans (mgmt, main ,and of course, IoT) then, I setup the same vlans on the switch, this wasn’t so bad since I put everything on a trunk port allowing traffic from/to anything and then filtering what goes through with firewall rules (I have no idea if this is best practice lol).
There are 3 trunk ports - the three of them allow all vlans to talk through there - I did this so I could have the access point do 2 diff wi-fi networks for IoT and main - but I have no idea if this was the best way to go about it, I also feel like the mgmt vlan is kind of not needed.
At some point, I stupidly installed some app updates on truenas scale and it broke everything, it broke all of my linux isos I torrented lol - which made me notice I don’t know shit about making my life easier with backups, snapshots and so on.
All of this confusion and kind-of-weird setup made want to re do everything, the right way. and here’s where I come to the pros out there so they can point me in the right direction or give me some tips/advice.
What is the right way?
Here’s all the hardware and plans I have :
Thinkserver RS140 ( planning on adding a 10Gib Nic to it and virtualizing PfSense on it), this would make the server have 2x10gib ports and 2x1gib port (there is one more 1Gib port for management)
Dell 3070 mini pc - I bought an adapter on aliexpress that uses the m.2 wlan port to add a second nic, I was thinking of installing proxmox on it, clustering it with the thinkserver, and virtualizing pf sense as well, and move the vm back and foward if I need to restart the Hypervisor so I can still have internet( is this even possible ? I was going through the HA documentation of netgate but none of them were specific enough, I don’t want fail over)
Since I hate the Aruba s1500 switch I got for free, I just want a good and nice managed switch that is small and it is fanless, I was thinking on buying the Ubiquiti Flex mini and also replace the Aruba AP with a unifi (one with wifi6, if possible)
For the optiplex 9020 I want to move the drive cage up (reference: https://www.youtube.com/watch?v=hXpo3rresqo&ab_channel=EJTech), add a PCI thingy for more SATA ports and make it a bigger NAS, where I also want to run proxmox on it and virtualized truenas scale, maybe add a GPU that would be good for hardware encoding.
The reasoning behind virtualizing everything is that I can do snapshots of crap before everything goes to hell I want to have a solid foundation to build upon - is this how YOU would do it?
Is this a feasible plan? would you change things based on the hardware I have? Where can I get the right info about this stuff without getting so confused? I like networking, but imho, I would rather buy some hardware that makes vlans and stuff a little easier but maybe I need to man up and just learn it? Learning with the aruba crap made me hate it, so that is why I wanted to change to the flex mini + unify AP. I also read somewhere here that Unifi is very overpriced and I can get the same from mikrotik, not sure how accurate that is tho.
I’m sorry if this does not make sense at all, English is my second language and sometimes I don’t make sense lol. If something is not clear enough please ask me and I am more than happy to give more info./clarification.
Thanks for reading this far, I am really excited to read your insight / thoughts on my situation.
