Sata power splitter
Hi guys,
Long time lurker and now finally doing my first post. I need some help about SATA splitter if I should use or not.
I have a Rosewill LSV-4500U. The 3 caddies support up to 5 drives so I was looking to get something clean with 5 sata power connector. I would like to get 1x (m) to 5x (f), but I am unable to find anything with more than 1 (m) to 4 (f) that is from a reputable brand like cable matters or startech. Everything else is from ebay or amazon.
Can I use these without any problem or I should avoid it ?
Thanks
I’m rebuilding mine and am in same boat. Did you find a good 5x SATA splitter?
Ive had good luck with these startech ones from - Amazon.com: StarTech.com 15.7 in (400 mm) SATA Power Splitter Adapter Cable - M/F - 4x Serial ATA Power Cable Splitter (PYO4SATA) : Electronics
The molded connector is the ones I read about a fire risk versus the press on connectors which pierce the cable.
This is also an interesting DIY approach - https://www.youtube.com/watch?v=Ls14BmwkeWg
