Sanity Check for new Proxmox/Plex Build
I’ve been using Proxmox and Plex for a few years now on a single chip Intel XEON @ 2GHZ. The motherboard is an EVGA mATX board and every once and awhile the whole think locks up. I’m looking for a new setup and was thinking about the following:
Motherboard: Supermicro X9DRI-F
Processors: 2x E5-2650L v1
RAM: 128GB (8x16GB) PC3-12800R 1600MHz DDR3 ECC Registered Memory For Supermicro X9DRi-F
GPU: NVIDIA 1060 6GB (used for hw transcoding and I already own this)
CPU Fans: 2x Arctic 33
I run plex on the host os and have 5 - 4TB drives in software raid 6 this storage is shared with all the different VM’s that I run. I’d like to go to 5 - 6TB drives using ZFS.
The only thing left is to find a case. I really wanted rack mount but the Rosewill is getting hard to find. I could base this whole thing off a Supermicro case but those PSU’s are loud and do not have the power for the GPU that I’d need.
Any thoughts/opinions/suggestions?
Sagz
You can get the SuperMicro X9DRL-iF with 2x Xeon E5-2650 v2, 16GB RAM and passive coolers for $199 (link below). I bought this combo recently and they currently have 6 left.
I ordered the same fans you picked as well, so good choice there. For the RAM, you should pick higher density chips (e.g. 32GB) to maximize any future upgrade options. I picked up 4 32GB ECC LRDIMM for $50 each ($200 combined). Keep in mind you can’t mix LRDIMMs with RDIMMs, so the memory in that combo likely won’t be useful unless you go RDIMM.
Motherboard Combo Deal
RAM I bought - Pardon Our Interruption...
