Hello! I am using rclone (1.53.3) in unraid (6.8.3) but I am facing certain issues with the rclone and Google Drive.
I have made this post with my explanation format and rclone’s official format too so that I could mention the issue in my words too for easy explanation and rclone’s format too for easy understanding.
Mounted Location: /mnt/disks/ua_hdd1/gdrive (ua_hdd1 is an unassigned disk/drive).
Command: rclone mount --allow-other --buffer-size 256M --dir-cache-time 96h --timeout 1h --default-permissions --uid 99 --gid 100 --umask 002 -vv gdrive: /mnt/disks/ua_hdd1/gdrive &
Now, I have actually mapped a network drive directly to this mounted location onto my Windows PC.
Issue: If I try to copy or do any action on this drive, it gives me a permission error “You need permission to perform this action”.
Screenshot: https://i.imgur.com/sAnLaeu.png
Error Log:
2020/12/26 23:07:09 ERROR : 100MB.bin: WriteFileHandle: Truncate: Can’t change size without --vfs-cache-mode >= writes
2020/12/26 23:07:10 ERROR : 100MB.bin: WriteFileHandle.Write: can’t seek in file without --vfs-cache-mode >= writes
2020/12/26 23:07:12 ERROR : 100MB.bin: WriteFileHandle.Write: can’t seek in file without --vfs-cache-mode >= writes
2020/12/26 23:07:13 ERROR : 100MB.bin: WriteFileHandle.Write: can’t seek in file without --vfs-cache-mode >= writes
(Log with -vv is shared below)
Solution: --vfs-cache-mode writes
But, this issue is only happening when I am doing the copy or any other action via. Windows SMB Share of this Folder.
If I submit a command root@unraid:/mnt/disks/ua_hdd1/test# cp 100MB.bin /mnt/disks/ua_hdd1/gdrive/Test1
It doesn’t throw the error as mentioned above and it directly uploads the file to Google Drive. Issue is only happening inside the Windows Share and it is perfectly working fine when, I am copying the file inside the unraid using the terminal/console.
So, Please assist me, how could I do the same when I’m using the smb share mapped network drive of this folder on the Windows OS.
unraid login user: root
Windows Mapped Drive user: adi (this is the user I have created in the unraid)
Screenshot: https://i.imgur.com/6PMNzZQ.png
Thanks.
Below is rclone forum’s official format:
What is the problem you are having with rclone?
What is your rclone version (output from rclone version)
1.53.3
Which OS you are using and how many bits (eg Windows 7, 64 bit)
rclone is installed on unraid and I am using Mapped Network Drive to the Mounted Location of Google Drive on my Windows 10 OS 64Bit.
Which cloud storage system are you using? (eg Google Drive)
Google Drive
The command you were trying to run (eg rclone copy /tmp remote:tmp)
The rclone config contents with secrets removed.
[gdrive]
type = drive
client_id = xxxx.apps.googleusercontent.com
client_secret = xxxx
scope = drive
token = {"access_token":"xxxxx","token_type":"Bearer","refresh_token":"xxxx","expiry":"2020-12-27T01:28:04.435079521+05:30"}
team_drive =xxxx
root_folder_id =
A log from the command with the -vv flag
2020/12/27 00:56:51 DEBUG : rclone: Version "v1.53.3" starting with parameters ["rcloneorig" "--config" "/boot/config/plugins/rclone/.rclone.conf" "mount" "--allow-other" "--buffer-size" "256M" "--dir-cache-time" "96h" "--timeout" "1h" "--default-permissions" "--uid" "99" "--gid" "100" "--umask" "002" "-vv" "gdrive:" "/mnt/disks/ua_hdd1/gdrive"]
2020/12/27 00:56:51 DEBUG : Creating backend with remote "gdrive:"
2020/12/27 00:56:51 DEBUG : Using config file from "/boot/config/plugins/rclone/.rclone.conf"
2020/12/27 00:56:51 DEBUG : Google drive root '': Mounting on "/mnt/disks/ua_hdd1/gdrive"
2020/12/27 00:56:51 DEBUG : : Root:
2020/12/27 00:56:51 DEBUG : : >Root: node=/, err=
2020/12/27 00:56:57 DEBUG : /: Attr:
2020/12/27 00:56:57 DEBUG : /: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:56:57 DEBUG : : Statfs:
2020/12/27 00:56:58 DEBUG : Google drive root '': read info from team drive "AlexJohn1"
2020/12/27 00:56:58 DEBUG : : >Statfs: stat={Blocks:274877906944 Bfree:274877906944 Bavail:274877906944 Files:1000000000 Ffree:1000000000 Bsize:4096 Namelen:255 Frsize:4096}, err=
2020/12/27 00:56:58 DEBUG : /: Attr:
2020/12/27 00:56:58 DEBUG : /: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:56:58 DEBUG : : Statfs:
2020/12/27 00:57:51 DEBUG : /: Attr:
2020/12/27 00:57:51 DEBUG : /: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:57:51 DEBUG : /: Lookup: name="Desktop.ini"
2020/12/27 00:57:51 DEBUG : Google drive root '': Checking for changes on remote
2020/12/27 00:57:51 DEBUG : /: >Lookup: node=, err=no such file or directory
2020/12/27 00:57:51 DEBUG : /: ReadDirAll:
2020/12/27 00:57:51 DEBUG : /: >ReadDirAll: item=11, err=
2020/12/27 00:57:51 DEBUG : /: Lookup: name="AutoRun.inf"
2020/12/27 00:57:53 DEBUG : /: Attr:
2020/12/27 00:57:53 DEBUG : /: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:57:53 DEBUG : : Statfs:
2020/12/27 00:57:53 DEBUG : : >Statfs: stat={Blocks:274877906944 Bfree:274877906944 Bavail:274877906944 Files:1000000000 Ffree:1000000000 Bsize:4096 Namelen:255 Frsize:4096}, err=
2020/12/27 00:58:01 DEBUG : /: Attr:
2020/12/27 00:58:01 DEBUG : /: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:01 DEBUG : /: Lookup: name="desktop.ini"
2020/12/27 00:58:01 DEBUG : /: >Lookup: node=, err=no such file or directory
2020/12/27 00:58:01 DEBUG : /: ReadDirAll:
2020/12/27 00:58:01 DEBUG : /: >ReadDirAll: item=11, err=
2020/12/27 00:58:01 DEBUG : /: Lookup: name="5GB1.bin"
2020/12/27 00:58:01 DEBUG : /: >Lookup: node=5GB1.bin, err=
2020/12/27 00:58:01 DEBUG : 5GB1.bin: Attr:
2020/12/27 00:58:01 DEBUG : 5GB1.bin: >Attr: a=valid=1s ino=0 size=1 mode=-rw-rw-r--, err=
2020/12/27 00:58:01 DEBUG : /: Lookup: name="P"
2020/12/27 00:58:01 DEBUG : /: >Lookup: node=P/, err=
2020/12/27 00:58:01 DEBUG : P/: Attr:
2020/12/27 00:58:01 DEBUG : P/: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:01 DEBUG : /: Lookup: name="Test1"
2020/12/27 00:58:01 DEBUG : /: >Lookup: node=Test1/, err=
2020/12/27 00:58:01 DEBUG : Test1/: Attr:
2020/12/27 00:58:01 DEBUG : Test1/: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:01 DEBUG : /: Lookup: name="bu"
2020/12/27 00:58:01 DEBUG : /: >Lookup: node=bu/, err=
2020/12/27 00:58:01 DEBUG : bu/: Attr:
2020/12/27 00:58:01 DEBUG : bu/: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:01 DEBUG : /: Lookup: name="media"
2020/12/27 00:58:01 DEBUG : /: >Lookup: node=media/, err=
2020/12/27 00:58:01 DEBUG : media/: Attr:
2020/12/27 00:58:01 DEBUG : media/: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:01 DEBUG : /: Lookup: name="media_swizzin"
2020/12/27 00:58:01 DEBUG : /: >Lookup: node=media_swizzin/, err=
2020/12/27 00:58:01 DEBUG : media_swizzin/: Attr:
2020/12/27 00:58:01 DEBUG : media_swizzin/: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:01 DEBUG : /: Lookup: name="nzb"
2020/12/27 00:58:01 DEBUG : /: >Lookup: node=nzb/, err=
2020/12/27 00:58:01 DEBUG : nzb/: Attr:
2020/12/27 00:58:01 DEBUG : nzb/: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:01 DEBUG : /: Lookup: name="test"
2020/12/27 00:58:01 DEBUG : /: >Lookup: node=test/, err=
2020/12/27 00:58:01 DEBUG : test/: Attr:
2020/12/27 00:58:01 DEBUG : test/: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:01 DEBUG : /: Lookup: name="torrent"
2020/12/27 00:58:01 DEBUG : /: >Lookup: node=torrent/, err=
2020/12/27 00:58:01 DEBUG : torrent/: Attr:
2020/12/27 00:58:01 DEBUG : torrent/: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:01 DEBUG : /: Lookup: name="youtube"
2020/12/27 00:58:01 DEBUG : /: >Lookup: node=youtube/, err=
2020/12/27 00:58:01 DEBUG : youtube/: Attr:
2020/12/27 00:58:01 DEBUG : youtube/: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:01 DEBUG : /: Lookup: name="yt"
2020/12/27 00:58:01 DEBUG : /: >Lookup: node=yt/, err=
2020/12/27 00:58:01 DEBUG : yt/: Attr:
2020/12/27 00:58:01 DEBUG : yt/: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:02 DEBUG : yt/: ReadDirAll:
2020/12/27 00:58:02 DEBUG : yt/: >ReadDirAll: item=1, err=
2020/12/27 00:58:02 DEBUG : yt/: Attr:
2020/12/27 00:58:02 DEBUG : yt/: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:02 DEBUG : yt/: Lookup: name="1"
2020/12/27 00:58:02 DEBUG : yt/: >Lookup: node=yt/1/, err=
2020/12/27 00:58:02 DEBUG : yt/1/: Attr:
2020/12/27 00:58:02 DEBUG : yt/1/: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:02 DEBUG : /: Attr:
2020/12/27 00:58:02 DEBUG : /: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:02 DEBUG : /: Lookup: name="yt"
2020/12/27 00:58:02 DEBUG : /: >Lookup: node=yt/, err=
2020/12/27 00:58:02 DEBUG : yt/1/: ReadDirAll:
2020/12/27 00:58:03 DEBUG : yt/1/: >ReadDirAll: item=0, err=
2020/12/27 00:58:03 DEBUG : yt/1/: Attr:
2020/12/27 00:58:03 DEBUG : yt/1/: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:05 DEBUG : /: Attr:
2020/12/27 00:58:05 DEBUG : /: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:05 DEBUG : : Statfs:
2020/12/27 00:58:05 DEBUG : : >Statfs: stat={Blocks:274877906944 Bfree:274877906944 Bavail:274877906944 Files:1000000000 Ffree:1000000000 Bsize:4096 Namelen:255 Frsize:4096}, err=
2020/12/27 00:58:05 DEBUG : /: ReadDirAll:
2020/12/27 00:58:05 DEBUG : /: >ReadDirAll: item=11, err=
2020/12/27 00:58:05 DEBUG : /: Lookup: name="5GB1.bin"
2020/12/27 00:58:05 DEBUG : /: >Lookup: node=5GB1.bin, err=
2020/12/27 00:58:05 DEBUG : 5GB1.bin: Attr:
2020/12/27 00:58:05 DEBUG : 5GB1.bin: >Attr: a=valid=1s ino=0 size=1 mode=-rw-rw-r--, err=
2020/12/27 00:58:05 DEBUG : /: Lookup: name="P"
2020/12/27 00:58:05 DEBUG : /: >Lookup: node=P/, err=
2020/12/27 00:58:05 DEBUG : P/: Attr:
2020/12/27 00:58:05 DEBUG : P/: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:05 DEBUG : /: Lookup: name="Test1"
2020/12/27 00:58:05 DEBUG : /: >Lookup: node=Test1/, err=
2020/12/27 00:58:05 DEBUG : Test1/: Attr:
2020/12/27 00:58:05 DEBUG : Test1/: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:05 DEBUG : /: Lookup: name="bu"
2020/12/27 00:58:05 DEBUG : /: >Lookup: node=bu/, err=
2020/12/27 00:58:05 DEBUG : bu/: Attr:
2020/12/27 00:58:05 DEBUG : bu/: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:05 DEBUG : /: Lookup: name="media"
2020/12/27 00:58:05 DEBUG : /: >Lookup: node=media/, err=
2020/12/27 00:58:05 DEBUG : media/: Attr:
2020/12/27 00:58:05 DEBUG : media/: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:05 DEBUG : /: Lookup: name="media_swizzin"
2020/12/27 00:58:05 DEBUG : /: >Lookup: node=media_swizzin/, err=
2020/12/27 00:58:05 DEBUG : media_swizzin/: Attr:
2020/12/27 00:58:05 DEBUG : media_swizzin/: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:05 DEBUG : /: Lookup: name="nzb"
2020/12/27 00:58:05 DEBUG : /: >Lookup: node=nzb/, err=
2020/12/27 00:58:05 DEBUG : nzb/: Attr:
2020/12/27 00:58:05 DEBUG : nzb/: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:05 DEBUG : /: Lookup: name="test"
2020/12/27 00:58:05 DEBUG : /: >Lookup: node=test/, err=
2020/12/27 00:58:05 DEBUG : test/: Attr:
2020/12/27 00:58:05 DEBUG : test/: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:05 DEBUG : /: Lookup: name="torrent"
2020/12/27 00:58:05 DEBUG : /: >Lookup: node=torrent/, err=
2020/12/27 00:58:05 DEBUG : torrent/: Attr:
2020/12/27 00:58:05 DEBUG : torrent/: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:05 DEBUG : /: Lookup: name="youtube"
2020/12/27 00:58:05 DEBUG : /: >Lookup: node=youtube/, err=
2020/12/27 00:58:05 DEBUG : youtube/: Attr:
2020/12/27 00:58:05 DEBUG : youtube/: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:05 DEBUG : /: Lookup: name="yt"
2020/12/27 00:58:05 DEBUG : /: >Lookup: node=yt/, err=
2020/12/27 00:58:05 DEBUG : yt/: Attr:
2020/12/27 00:58:05 DEBUG : yt/: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:05 DEBUG : /: Lookup: name="100MB.bin"
2020/12/27 00:58:05 DEBUG : /: >Lookup: node=, err=no such file or directory
2020/12/27 00:58:05 DEBUG : /: Create: name="100MB.bin"
2020/12/27 00:58:05 DEBUG : 100MB.bin: Open: flags=O_RDWR|O_CREATE|O_EXCL
2020/12/27 00:58:05 DEBUG : : Added virtual directory entry vAdd: "100MB.bin"
2020/12/27 00:58:05 DEBUG : 100MB.bin: >Open: fd=100MB.bin (w), err=
2020/12/27 00:58:05 DEBUG : /: >Create: node=100MB.bin, handle=&{100MB.bin (w)}, err=
2020/12/27 00:58:05 DEBUG : 100MB.bin: Attr:
2020/12/27 00:58:05 DEBUG : 100MB.bin: >Attr: a=valid=1s ino=0 size=0 mode=-rw-rw-r--, err=
2020/12/27 00:58:05 DEBUG : 100MB.bin: Setattr: a=Setattr [ID=0xbf Node=0xe Uid=99 Gid=100 Pid=610] mode=-rw-rw-rw- handle=INVALID-0x0
2020/12/27 00:58:05 DEBUG : 100MB.bin: >Setattr: err=
2020/12/27 00:58:05 DEBUG : 100MB.bin: Setattr: a=Setattr [ID=0xc0 Node=0xe Uid=99 Gid=100 Pid=610] size=104857600 handle=0x2 lockowner
2020/12/27 00:58:05 DEBUG : 100MB.bin: Truncating 1 file handles
2020/12/27 00:58:05 ERROR : 100MB.bin: WriteFileHandle: Truncate: Can't change size without --vfs-cache-mode >= writes
2020/12/27 00:58:05 DEBUG : 100MB.bin: >Setattr: err=operation not permitted
2020/12/27 00:58:05 DEBUG : &{100MB.bin (w)}: Write: len=1, offset=104857599
2020/12/27 00:58:05 DEBUG : 100MB.bin: waiting for in-sequence write to 104857599 for 1s
2020/12/27 00:58:06 DEBUG : 100MB.bin: aborting in-sequence write wait, off=104857599
2020/12/27 00:58:06 DEBUG : 100MB.bin: failed to wait for in-sequence write to 104857599
2020/12/27 00:58:06 ERROR : 100MB.bin: WriteFileHandle.Write: can't seek in file without --vfs-cache-mode >= writes
2020/12/27 00:58:06 DEBUG : &{100MB.bin (w)}: >Write: written=0, err=illegal seek
2020/12/27 00:58:06 DEBUG : &{100MB.bin (w)}: Write: len=1, offset=0
2020/12/27 00:58:06 DEBUG : : Added virtual directory entry vAdd: "100MB.bin"
2020/12/27 00:58:06 DEBUG : &{100MB.bin (w)}: >Write: written=1, err=
2020/12/27 00:58:06 DEBUG : /: Attr:
2020/12/27 00:58:06 DEBUG : /: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:06 DEBUG : 100MB.bin: Setattr: a=Setattr [ID=0xc4 Node=0xe Uid=99 Gid=100 Pid=610] atime=2020-12-27 00:58:05.376145022 +0530 IST mtime=2020-12-27 00:58:06.380347038 +0530 IST handle=INVALID-0x0
2020/12/27 00:58:06 DEBUG : 100MB.bin: >Setattr: err=
2020/12/27 00:58:06 DEBUG : 100MB.bin: Attr:
2020/12/27 00:58:06 DEBUG : 100MB.bin: >Attr: a=valid=1s ino=0 size=1 mode=-rw-rw-r--, err=
2020/12/27 00:58:06 DEBUG : &{100MB.bin (w)}: Write: len=131072, offset=0
2020/12/27 00:58:06 DEBUG : 100MB.bin: waiting for in-sequence write to 0 for 1s
2020/12/27 00:58:07 DEBUG : 100MB.bin: aborting in-sequence write wait, off=0
2020/12/27 00:58:07 DEBUG : 100MB.bin: failed to wait for in-sequence write to 0
2020/12/27 00:58:07 ERROR : 100MB.bin: WriteFileHandle.Write: can't seek in file without --vfs-cache-mode >= writes
2020/12/27 00:58:07 DEBUG : &{100MB.bin (w)}: >Write: written=0, err=illegal seek
2020/12/27 00:58:07 DEBUG : 100MB.bin: Attr:
2020/12/27 00:58:07 DEBUG : 100MB.bin: >Attr: a=valid=1s ino=0 size=1 mode=-rw-rw-r--, err=
2020/12/27 00:58:07 DEBUG : &{100MB.bin (w)}: Write: len=131072, offset=1048576
2020/12/27 00:58:07 DEBUG : 100MB.bin: waiting for in-sequence write to 1048576 for 1s
2020/12/27 00:58:07 DEBUG : /: Attr:
2020/12/27 00:58:07 DEBUG : /: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:08 DEBUG : 100MB.bin: aborting in-sequence write wait, off=1048576
2020/12/27 00:58:08 DEBUG : 100MB.bin: failed to wait for in-sequence write to 1048576
2020/12/27 00:58:08 ERROR : 100MB.bin: WriteFileHandle.Write: can't seek in file without --vfs-cache-mode >= writes
2020/12/27 00:58:08 DEBUG : &{100MB.bin (w)}: >Write: written=0, err=illegal seek
2020/12/27 00:58:08 DEBUG : &{100MB.bin (w)}: Write: len=131072, offset=2097152
2020/12/27 00:58:08 DEBUG : 100MB.bin: waiting for in-sequence write to 2097152 for 1s
2020/12/27 00:58:09 DEBUG : 100MB.bin: aborting in-sequence write wait, off=2097152
2020/12/27 00:58:09 DEBUG : 100MB.bin: failed to wait for in-sequence write to 2097152
2020/12/27 00:58:09 ERROR : 100MB.bin: WriteFileHandle.Write: can't seek in file without --vfs-cache-mode >= writes
2020/12/27 00:58:09 DEBUG : &{100MB.bin (w)}: >Write: written=0, err=illegal seek
2020/12/27 00:58:09 DEBUG : &{100MB.bin (w)}: Write: len=131072, offset=3145728
2020/12/27 00:58:09 DEBUG : 100MB.bin: waiting for in-sequence write to 3145728 for 1s
2020/12/27 00:58:10 DEBUG : 100MB.bin: aborting in-sequence write wait, off=3145728
2020/12/27 00:58:10 DEBUG : 100MB.bin: failed to wait for in-sequence write to 3145728
2020/12/27 00:58:10 ERROR : 100MB.bin: WriteFileHandle.Write: can't seek in file without --vfs-cache-mode >= writes
2020/12/27 00:58:10 DEBUG : &{100MB.bin (w)}: >Write: written=0, err=illegal seek
2020/12/27 00:58:10 DEBUG : &{100MB.bin (w)}: Write: len=131072, offset=4194304
2020/12/27 00:58:10 DEBUG : 100MB.bin: waiting for in-sequence write to 4194304 for 1s
2020/12/27 00:58:11 DEBUG : 100MB.bin: aborting in-sequence write wait, off=4194304
2020/12/27 00:58:11 DEBUG : 100MB.bin: failed to wait for in-sequence write to 4194304
2020/12/27 00:58:11 ERROR : 100MB.bin: WriteFileHandle.Write: can't seek in file without --vfs-cache-mode >= writes
2020/12/27 00:58:11 DEBUG : &{100MB.bin (w)}: >Write: written=0, err=illegal seek
2020/12/27 00:58:11 DEBUG : &{100MB.bin (w)}: Write: len=131072, offset=5242880
2020/12/27 00:58:11 DEBUG : 100MB.bin: waiting for in-sequence write to 5242880 for 1s
2020/12/27 00:58:12 DEBUG : 100MB.bin: aborting in-sequence write wait, off=5242880
2020/12/27 00:58:12 DEBUG : 100MB.bin: failed to wait for in-sequence write to 5242880
2020/12/27 00:58:12 ERROR : 100MB.bin: WriteFileHandle.Write: can't seek in file without --vfs-cache-mode >= writes
2020/12/27 00:58:12 DEBUG : &{100MB.bin (w)}: >Write: written=0, err=illegal seek
2020/12/27 00:58:12 DEBUG : &{100MB.bin (w)}: Write: len=131072, offset=6291456
2020/12/27 00:58:12 DEBUG : 100MB.bin: waiting for in-sequence write to 6291456 for 1s
2020/12/27 00:58:13 DEBUG : 100MB.bin: aborting in-sequence write wait, off=6291456
2020/12/27 00:58:13 DEBUG : 100MB.bin: failed to wait for in-sequence write to 6291456
2020/12/27 00:58:13 ERROR : 100MB.bin: WriteFileHandle.Write: can't seek in file without --vfs-cache-mode >= writes
2020/12/27 00:58:13 DEBUG : &{100MB.bin (w)}: >Write: written=0, err=illegal seek
2020/12/27 00:58:13 DEBUG : &{100MB.bin (w)}: Write: len=131072, offset=7340032
2020/12/27 00:58:13 DEBUG : 100MB.bin: waiting for in-sequence write to 7340032 for 1s
2020/12/27 00:58:14 DEBUG : 100MB.bin: aborting in-sequence write wait, off=7340032
2020/12/27 00:58:14 DEBUG : 100MB.bin: failed to wait for in-sequence write to 7340032
2020/12/27 00:58:14 ERROR : 100MB.bin: WriteFileHandle.Write: can't seek in file without --vfs-cache-mode >= writes
2020/12/27 00:58:14 DEBUG : &{100MB.bin (w)}: >Write: written=0, err=illegal seek
2020/12/27 00:58:14 DEBUG : 100MB.bin: Attr:
2020/12/27 00:58:14 DEBUG : 100MB.bin: >Attr: a=valid=1s ino=0 size=1 mode=-rw-rw-r--, err=
2020/12/27 00:58:14 DEBUG : /: Attr:
2020/12/27 00:58:14 DEBUG : /: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:14 DEBUG : /: Remove: name="100MB.bin"
2020/12/27 00:58:14 DEBUG : 100MB.bin: Remove:
2020/12/27 00:58:14 DEBUG : : Added virtual directory entry vDel: "100MB.bin"
2020/12/27 00:58:14 DEBUG : 100MB.bin: >Remove: err=
2020/12/27 00:58:14 DEBUG : /: >Remove: err=
2020/12/27 00:58:14 DEBUG : &{100MB.bin (w)}: Flush:
2020/12/27 00:58:14 DEBUG : Google drive root '': File to upload is small (1 bytes), uploading instead of streaming
2020/12/27 00:58:16 DEBUG : 100MB.bin: MD5 = 93b885adfe0da089cdf634904fd59f71 OK
2020/12/27 00:58:16 INFO : 100MB.bin: Copied (new)
2020/12/27 00:58:17 DEBUG : 100MB.bin: Applied pending mod time 2020-12-27 00:58:06.380347038 +0530 IST OK
2020/12/27 00:58:17 DEBUG : : Added virtual directory entry vAdd: "100MB.bin"
2020/12/27 00:58:17 DEBUG : &{100MB.bin (w)}: >Flush: err=
2020/12/27 00:58:17 DEBUG : &{100MB.bin (w)}: Release:
2020/12/27 00:58:17 DEBUG : 100MB.bin: WriteFileHandle.Release nothing to do
2020/12/27 00:58:17 DEBUG : &{100MB.bin (w)}: >Release: err=
2020/12/27 00:58:17 DEBUG : /: Attr:
2020/12/27 00:58:17 DEBUG : /: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:17 DEBUG : : Statfs:
2020/12/27 00:58:17 DEBUG : : >Statfs: stat={Blocks:274877906944 Bfree:274877906944 Bavail:274877906944 Files:1000000000 Ffree:1000000000 Bsize:4096 Namelen:255 Frsize:4096}, err=
2020/12/27 00:58:24 DEBUG : /: Attr:
2020/12/27 00:58:24 DEBUG : /: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:47 DEBUG : /: Attr:
2020/12/27 00:58:47 DEBUG : /: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
2020/12/27 00:58:51 DEBUG : Google drive root '': Checking for changes on remote
2020/12/27 00:58:51 DEBUG : : changeNotify: relativePath="100MB.bin", type=3
2020/12/27 00:58:51 DEBUG : : invalidating directory cache
2020/12/27 00:58:51 DEBUG : : >changeNotify:
2020/12/27 00:59:51 DEBUG : Google drive root '': Checking for changes on remote
2020/12/27 01:00:51 DEBUG : Google drive root '': Checking for changes on remote
2020/12/27 01:01:02 DEBUG : /: Attr:
2020/12/27 01:01:02 DEBUG : /: >Attr: attr=valid=1s ino=0 size=0 mode=drwxrwxr-x, err=
