I recently was gifted a Gen 8 Proliant DL380p. I was so excited to get the box I started shopping and didn’t do my research properly.
I picked up one of the f40 400gb cards, but it has a low profile bracket. It looks like I can order a bracket for about $10 with a quick look.
Here is the question - do I need the bracket, or could I slide by without a bracket for some time (it may be moved to a different box with the low profile slot).
I don’t have first hand experience with that specific card, but if it is even a little bit top heavy you might need to fashion some kind of support to keep it from stressing the slot.
