Hi,
I am new to all of this and wanted to hear your thought and suggestions about my plan I gathered after researching with zero prior knowledge. Thanks in advance!
- My main goals are having a local storage of family photos and docs, a secondary goal is streaming media to other devices(not more than 1-2 simultaneously). Also wanted to keep cost as low as possible - both upfront hw cost and recurring power consumption cost. In addition wanted to prepare to the future, when maybe I will need some more disks(but this is quite far down the road).
- I thought about an firebat t8 intel n100 mini pc with 16gb ram, 500 gb ssd and an external enclosure with 2x4tb hdds. The hdds are for the data I don’t want to lose, and the ssd is more for media to stream(i dont care about losing some movies if the drive fails). I plan to use omv and run it from a 64 gb flash drive(i understood i have to use a specific plugin for that)
- is it ok to buy this mini pc from ebay? the seller seems reputable with some thusands of reviews all positive. But I never bought hardware from ebay and am afraid of getting garbage.
- I learned that raid is not a backup, so wanted to make a periodic backup of the first hdd into the second one. As stated earlier, no backup for the ssd and since the flash drive is tiny so will backup it too to the hdd(I saw it should be supported in omv)
- Didn’t decide yet regarding remote backup, i want the cheapest solution, but also to make sure its robust and easy to use. Will be glad to get some wisdom from you and hear how you do it. I understood there is a plugin for that, and that many recommend to use rsync, bit i am quite clueless about the tradeoffs here.
- Regarding the disks enclosure, are there cons for connecting it via usb 3.0 compared to disks directly connected via sata? If I want more storage in the future, I will be able to just buy additional enclosure and connect it via another usb 3 port with no problems right?
- Any suggestions regarding selecting the enclosure? Things to look for? Caveats? I thought about Maivo K35272U3 just since it seems like the cheapest I could find in my area.
- I understood there are disks specifically made for nas use(wd red and seagate ironwolf), will i have any gain in using them? Or maybe in such a minimalist solution their extra features won’t benefit much? Any other suggestion for reliable cheap disks? Performance is not much of a concern for my usecase. I tend toward the ironwolf since I understood they are more reliable and should last for longer, and heard some WD red are SMR which is considered inferior.
- Is the selection of omv make sense? Tried to read about truenas as well but didnt really understood the differences.
- I plan to use immich as a google photos alternatice and jellyfin for streaming content
I know it came out a very long post, so huge thanks if you read it all the way to the end. Can’t wait to hear your inputs! Thanks again!!
