NSFW Build Complete
Made a fantastic build with the awesome guidance of serverbuilds.net
This server is being used as one of my ESXi hosts that will host all my primary stuff.
Currently I’m running this set up:
Xpenology, sonarr/radarr/nzbget (docker containers on the Xpenology server), PFSense, AD Domain Controller, PiHole, vCenter, and nginx (reverse proxy for services).
Planning on deploying nextcloud, bitwarden, and a few other services.
Here’s a spreadsheet of the parts, prices, and sources:
Part Make/Model Price Supplier Delivered
Motherboard GA-7PESH2 GIGABYTE Intel Rev1.0 $185.00 MetServers YES
CPU E5-2650 V2 (x2) $140.00 Ebay - MetServers YES
Memory SAMSUNG 8GB 2Rx4 PC3-10600R (x2) $23.38 Ebay - corpreccouncil YES
Power Supply Corsair CX 650 $59.99 Amazon YES
Case Rosewill RSV-R4000 $85.41 Amazon YES
Case Fan ARCTIC F8 PWM PST $22.98 Amazon YES
CPU Fan ARCTIC Freezer 12 (x2) $39.98 Amazon YES
Case Fan ARCTIC F12 PWM PST $26.95 Amazon YES
Cable Cable Matters (2 Pack) 15 Pin SATA to 4 SATA Power Splitter Cable $11.99 Amazon YES
Cable EPS Y Cable $8.45 Ebay - antronst YES
Cable Electop 2-Pack Bezel Wire Kit $5.99 Amazon YES
Cable Mini SAS Cable Connector (x2) $27.18 Amazon YES
HDD 3TB HGST SAS 3.5 HUS723030ALS640 (x4) $100.00 Ebay - wholesaleprices11 YES
Switch Cisco SG300-10 $45.00 Ebay - greenteksolutions YES
Adapter SG300-10 Adapter $13.99 Ebay - monster.parts YES
Total
$796.29
I had a few parts that I had from previous projects. Specifically 48GB of ram, 2 250GB SSDs, and a 1TB WD Blue HDD.
Here’s a few pictures:
Nice build, I have the same case and the only thing I do not like about it is having to disconnect 5 drives to upgrade one drive.
Understandable, but when I was trying to figure out which drive was DOA (they replaced it very quickly), If found that I had enough slack to remove just one if I pulled it slightly forward.
All in all, it’s not a bad case, but I would love to get some of those hotswap cages
The RSV-L4412 – 4U is hot-swappable…I may look into that for a future build and would like make life easier.
Is your airflow going back to front?
No, the airflow is front to back.
Your fans are in the wrong way then. I can’t see the front ones but the rear ones are sucking air in through the back.
Interesting. I had tested the fan flow and I thought it flowed out. I’ll check again.
the open side of the fans is intake, the side with the motor is exhaust.
Hol up :slight_smile:
The airflow is front to back not back to front.
I mis-read his question lol
Just like wiping, always go front to back.
In that case your fans are set up wrong.
In that picture they were. I’ve since fixed it.
I can see where the confusion is coming from.
I’ll update the picture when I get home.
We just prefer when builds blow rather than when builds suck :smile:
