@JDM_WAAAT got a lil question. I have an rx580 sitting around and thought maybe I should throw it in my Plex box? Would that be an upgrade to the iGPU on the i3-8100? Or am I better off without it?
I’m planning a build similar to this and curious what you ended up with? Did the AsRock board fit? Did you go with the Node 304 or the Core V1?
Went with the node 304 and the asus 310 motherboard from a few posts up. I couldn’t be happier with what I build.
Thanks, great to hear. What OS did you install?
For anyone else that reads old post as info, I can now say for a fact that the Fractal Designs Node 304 and the ASROCK H310CM-HDV LGA 1151 are not compatible.
It is oh so very close, but the power supply mount is in the way.
