I currently run a QNAP 8 bay NAS in a raid 6 array. As my disks were so expensive, I want to migrate to an UNRAID solution with purchasing as few new disks as possible.
What’s the best way to achieve this?
Ultimately I want an UNRAID NAS with double disk parity (to protect against a single disk parity drive failure).
You’ll need to back up everything on you QNAP as the data is not transferable from Raid.
The data on all drives will be wiped when building a parity array. You can start with one parity drive and add a second later if required. I have dual parity.
Once your array is built simply transfer the data from your backups over.
