Encouraged on Reddit to ask my question here, so here it is:
Hi all
I want to build a small NAS mostly for file sharing and backups.
The things I consider absolutely necessary:
Lowest power usage possible -
Highest write/read speeds in LAN possible (1Gbps LAN) -
Small size, needs to go in a tight space, so as small as possible -
Around 3-4 bays for 3.5" HDDs (one for parity) -
m.2 slot for caching (not necessary though, it could also be an SSD)
I am replacing an old Synology DS120j, so I am sure anything above that will be way faster.
The mahine will be storing large 4k video files but will not be doing any Plex transcoding at all. It is mainly a share for all other LAN devices to share files
I am not interested in the following:
Any form of transcoding -
Any form of VM -
Any form of Docker (or other) containers -
No ARM, must be x86
Trying to find a cost effective solution (aren’t we all), but if the hardware satisfies the requirements above, then it’s ok if it costs a bit more.
Your suggestions please?
