Hi
Looking at the Noctua NH-U14S, Premium CPU Cooler with NF-A15 140mm Fan, however, could someone confirm whether it will fit a ‘SUPERMICRO X10SLQ LGA1150 H3 MICRO-ATX’ in a Fractal Node 804?
Thanks
Hi
Thanks
Just found the spec of the Fractal Node 804 and it states that the max size of CPU Cooler is 160mm and I think the Noctua NH-U14S is 165mm, so don’t think it will fit ![]()
Any advice on either the Noctua NH-U9S or Hyper 212 Evo (CPU is i7-4770K)?
Thanks
Check this list. Anything here will fit in the Node 804, you can verify the height if you want.
Hi
Thanks for you suggestions, I’ve gone with the ‘Arctic Freezer 34 eSports DUO’.
