zepher
December 15, 2020, 6:03pm
1
I was wondering if anyone has managed to put a CoolerMaster Hyper 212 Evo into a RSV-L4500? Not sure if I am going to have to buy a new CPU cooler for my next server build.
dhole
December 15, 2020, 6:08pm
2
Not without cutting a hole for the heat pipes.
Refer to heatsink height here:
Air Cooling
Notes
Generally speaking, Arctic makes a product that works for every solution.
They are affordable, high performance, quiet, and well built.
LGA115X = LGA1156, LGA1155, LGA1150, LGA1151, LGA1200
LGA115X (hole/backplate)
Consumer motherboards usually have pass through holes.
Xeons often have permanently attached backplates, forcing you to use its mounting threads.
LGA1366/1356 = Xeon support with fixed backplate
All LGA2011 models include fixed backplate, regardless of consumer …
