Says $64.50 and free shipping.
Certainly more than a laptop external, but not that bad.
Iām thinking about building the 6-bay Mini-ITX NAS as my first server. I would like to run the latest Ubuntu Server as the OS. How well would this work?
A post was split to a new topic: New to homelab - moe
This would all depend on your needs. What are you trying to do with your server?
A post was split to a new topic: Upgrade options from AMD A6-5400K
hi peaple, tryng to make work my first build but⦠letās talk about money.
how much energy will consume an i7 3770 with a DQ77MK Q77, 8 gb of ram and 3-4 drives?
iām planning to upgrade it even with a low profile gpu for multiple streaming, is it worth it?
Hey noob here. Just wanted to say thanks for the guide. Iām new to NAS and home server builds - I recently setup an HP Mini 800 G4 with an i7 6600T, 16GB ram, 256GB nvme with proxmox, pfSense as a VM and a cheap netgear managed switch with VLANs to route WAN/LAN traffic. Also 4 atomic pis I setup as nodes to cluster for playing with. Digging the home setup and what Iām learning so far.
I have an i7-2600s, 2x4gb SO-DIMM ram, 3tb, 1tb, 500gb, 250gb 3.5" disks and a couple of 19.5v HP power supplies that were for their SFF (19.5v, 135w-180w) all lying around and wanted to build out a simple NAS for media and serving the VMs and aPis. Iām trying to find a reasonable DQ77KB and get a case, possibly a Cooler Master Elite RC-110 and Iād be all set. The mobos are bit hard to come by at this point other than $100 listings on eBay but I would like to finish up with $100 tops for the case/mobo. Would a Gigabyte GA-H77TN fill the mobo requirement okay for something similar to the 6-bay Mini-ITX NAS?
Thanks for the awesome guide. I just orderded my parts, X9SCL w/ E3-1220 V2, 8GB PC3-12800E, LSI 9210-8i. I decided to go with the Fractal Design Define R5 for the case since I currently have a Meshify S2 and like their products. The Antec P101 looked like another decent option, although neither a ābudgetā case. The Node 804 looks pretty nice as well, but I donāt care for the window and want the option of using a full size ATX board in the future. Now I just need to decide on using shucked WD drives or paying a lot more for āNASā drives. Iām leaning towards Unraid, but will look into OMV as well.
edit: The Fractal case came in slightly damaged, I wasnāt sure if I should bother returning it or not since it wasnāt too noticeable. Then I checked Newegg and they have the Antec P101 on sale for $85 AR. The Define 5 was $130 + $14 for a 2nd intake fan, so that made my decision easy. Returnig the Define 5 and ordered the P101.
The Dell prebuilt option is labeled as " Dell Poweredge T210 II" but I think you meant " Prebuilt Dell Poweredge T110 II"
Wanted to give a shoutout to crew running this board. Iāve got my NK4.1 up running Centos 8.1 with 6x8TB in raidz2. Iām replacing a QNAP TS-251 that I paid $350 for 5 years ago (for hardware and RAM). For well less than that, Iāve got a ton more performance plus a Mellanox Connectx-3 10gb nic.
If anyone is interested in doing a Centos build, Iām happy to share some tips to resolve issues I had to address.
Hiā¦Iām in the process of upgrading my unRAID server since Iām currently running it on an old Phenom 965. But, Iāve started to play with VMs and my actual config canāt do GPU passthrough. So, I would like to build an unRAID server capable of GPU passthrough for 3 concurrents gaming VMs with 3 GPU. And for now, I hesitate between a brand new 2700x on an Asus board or an old dual Opteron (G34) or dual Xeon on a Supermicro board or any other dual Xeon socket motherboard.
Hi,
Is there anyone that bought components for nk4.0 that would fit fractal node 304 or similar case? Iāve created new thread in main forum NK4 with parts from EU
Hi, I was looking into building the mini-itx build as described, but itās looking like the recommended motherboard DQ77KB is in short supply and whatever stock is available is pretty expensive. Unfortunately physical space is a consideration for me, so I would really like to go with a mini-itx build. Are there any other mini-itx boards that could be substituted for the DQ77KB and keeping the rest of the build the same?
Hey, I have some old hardware that I was hoping to re-purpose for a NAS. I plan to have it host media to a separate Plex Server, a combination of 4K x265 and 1080p x264 content.
Trying to keep costs to a minimum here while achieving a stable/capable build, here are the components I have already:
Motherboard: Asus P8P67 Revolution
CPU: i7-2600K
Memory: 16GB (4x 4GB) Corsair DDR3-1600 / PC3-12800 DDR3 SDRAM UDIMM
SSD: Crucial M4 128GB SATAIII CT128M4SSD2
Before I begin setting up Unraid and throwing some HDDās in the case, is there anything I should swap out from the list above?
Thanks, I appreciate your help!
Interested in starting with a Dell PowerEdge T110ii but have a few questions.
The guide says it has 5 3.5" bays but all the documentation and photos Iāve found only show 4. Can anyone confirm it has 5?
My understanding is that it has 5 internal SATA ports. Can all of them be used with UNRAID? Another thread suggested that they couldāt be used because theyāre provided by an integrated RAID controller and that a SAS expander should be purchased.
Thanks
I am currently using a Dell PowerEdge T110II as my unraid box, it only has 4 3.5" bays, but you can likely find a drive cage for the 5.25" bay, or what I did was just velcro an SSD into the gap below the DVD drive for my cache.
Yes it has 5 internal SATA ports. The default config has 1 of them for the DVD, but Iām currently using all 5 for drives in unraid. You can easily disable the built in RAID via bios.
By drive cage do you mean a single cage that holds multiple drives? It looks like the tower only has 2 external 5.25" bays and most HDD cages take up 3?
In this case if you just wanted to make use of the 5th SATA port with a mechanical hard drive you could get a 5.25" to 3.5" bay converter kit that holds 1 drive. If you were thinking of adding a SAS card there are modules that covert 2 5.25" to 3 3.5" drive bays. Some of them are even hot swapable.
Decided to build my own. What do you guys think of the Intel S1200BTL? Xeon and Core i3, 2 x SATA3, 4 x SATA2, ECC UDIMM only, ATX, 3 x PCI-E VGA only, dual NICs. There are several on eBay for $30.
