Unraid Server
- CPU: Intel Xeon E3-1270 SR00N 3.4GHz Quad Core LGA 1155 Processor CPU *km
- CPU Cooler: Cooler Master Hyper 212 Black Edition CPU Air Cooler, Silencio FP120 Fan, Anodized Gun-Metal Black, Brushed Nickel Fins, 4 Copper Direct Contact Heat Pipes for AMD Ryzen/Intel LGA1700/1200/1151
*Motherboard: Supermicro X9SCM-F M-ATX Intel C204 LGA 1155 Motherboard W/ E3-1270 and 8GB DDR3
*RAM: A-Tech 32GB 4x 8GB PC3-12800 Desktop DIMM 240pin DDR3 1600MHz Non-ECC Memory RAM - Harddrives: Seagate IronWolf NAS 8 TB 3.5" 7200 RPM Internal Hard Drive X 10
*SSD Cache Drive: Intel DC P4500 Series SSDPE2KX020T7 2.0TB NVMe PCIe U.2 2.5" Solid State Drive
*Case: Antec P101 Silent Performance Series Mid-Tower PC Computer Case with Sound Dampening Panels, 4 X 120/140mm Cooling Fans Pre-Installed
*Power Supply: Cooler Master Watt 650 Watt Semifanless Modular Power Supply, 80 PLUS Bronze Certified Power Supply for Computers
*SATA HBA: YUNKOZAND PCIE 1X SATA Card 16 Ports,with 16 SATA Cables and Low Profile Bracket,PCIE to SATA 3.0 6 Gbps Controller,PCIE to SATA Expansion Card,SATA Controller,SATA PCIE Card,ASM1064+3JMB575 Chips
*Fan: ARCTIC P12 PWM PST (5 Pack) - 120 mm Case Fan, PWM Sharing Technology (PST), Pressure-optimised, Value Pack, Very quiet motor, Computer, 200-1800 RPM - Black
I Bought a QuickSync Box, to be used for plex, and an unraid server, will be using 10 hard drives.
I’m hoping to figure out data retention or something similar like snapshot, but would this Tower server work I’ve asked a lot of advice in the discord channel. wanted to ask one more time before purchasing this bundle server!
