I will use a LSI 9207-8e in a HP 800 G4 SFF.
Almost definitely and probably
is there a fan I can add to it with zip tie etc, or add inside the case? any guidance?
I saw some people cut a hole in top cover and add a fan etc but I’m not experienced enough to do that
Yes you can add a fan if you like. Zip ties are a fine option.
