DS4243/DS4246 PSU Teardown
Hey everyone,
Quick teardown of a power supply for the DS4243/DS4246 disk shelf.
WARNING:
Please be very careful and aware of the capacitors, they are deadly. do your best to discharge them. Even if you are confident that they are discharged, still be very careful.
Supplies:
  • Philips head screwdriver
  • Needle nose pliers
Removing the screws from the outer casing is pretty easy.
14 screws on the sides of the casing and then it slides off pretty easily.
There are these long bolts with nuts holding both of the fans in.
You need to hold the nuts while unscrewing these otherwise they just slip.
The fan wires are zip-tied to three anchors on the casing, so those need to be cut.
After this, the heat shrink tubing around the wire bundle can be slid down and the fans can be pulled out.
I did have some difficulty removing the fan closet to the rear because of lip for the casing screws.
These are 80mm * 80mm * 35mm DC12v 3.30A 3-pin fans
They are soldered to to and epoxied(I think that is what the white stuff is?) to a board at the front of the PSU.
So there will defiantely need to be some soldering or crimping to replace these fans
Hopefully this can help some other people looking to replace the fans for some quieter ones!
Edit: added warning
This is great did you replace them?
What with?
thanks :smiley:
Why is your name DS4243
I have not replaced them yet.
However I was looking at these Arctic Fans
I have 6 of these that I’m doing a long term project with, and it’s probably going to be awhile before I get them up and running.
I Don’t know! :stuck_out_tongue:
Did you ever replace the fans? I have tried one with Generic 12V quiet fans, but all PSU’s run at full speed when inserted, so the speed pulse is not correct.
I have not. It’s sitting in my closet where I left it after finishing this teardown
I just got my DS4246 going this week and other than the initial power on, they’re actually quieter than my Juniper EX2200.
Now if I could just figure out why drives are being detected as 6Gbps capable but are currently 3Gbps:
root@pve:~ # smartctl -d sat -i /dev/sdb
smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.3.18-3-pve] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Seagate Enterprise Capacity 3.5 HDD
Device Model: ST8000NM0055-1RM112
Serial Number: ZA1GF540
LU WWN Device Id: 5 000c50 0c3f405b3
Firmware Version: SN05
User Capacity: 8,001,563,222,016 bytes [8.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Wed Apr 8 10:38:08 2020 EDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
Shouldn’t matter, HDD won’t hit even 3Gbps.
