Yes, I have port conflicts with one or more containers, Unifi being one of them. Simply changing the port mapping does not always help as it should. It is easier to put it on the bridged interface. In the instance of pihole, i would rather my dns not go to the server IP.
I still have this issue ongoing sometimes when i restart the server or stop/start the array. Hoping that it gets fixed in 6.9 or maybe it’s just a bug in my install. These two commands work like a charm every time instead of stopping/starting the array again.
Way late seeing this. Came back to update. I do not have bonding enabled.
eth0 is on 192.168.1.0/24 with bridging enabled. eth1 is in 192.168.99.0/24 with bridging enabled.
VMs on both br0 and br1 obtain IPs just fine.
Docker however has the issue I initially described and it only still fixed by running those two commands. I just created a user script to run at array startup so I don’t have to do it manually when I restart the server every few months.
