Disassembly Guide for Ugreen DX4700 Test Unit
I just wanted to document the steps for disassembly. In the event someone wanted to repurpose one of these devices it is necessary to disassemble to access the BIOS through a hidden HDMI port.
Disassembly Steps
  1. Remove RAM/M.2 cover
  • Take off the RAM/M.2 cover.
  • Watch out for the spring-loaded pin—it’s captive, but it will get in the way later.
  1. Back cover screws
  • Remove the four rubber stoppers on the back to access the screws underneath.
  • Once those screws are out, use a PCIe slot cover (hook it through the fan grate, with the short flat side against the underside) to gently pull until the back cover loosens.
  • Alternatively, needle-nose pliers with a steady hand can work—just be careful not to damage anything.
  1. Remove the fan
  • The fan is secured with four long screws—remove them to take the fan out.
  1. Brackets and case separation
  • There are two narrow brackets with four screws each, partially covered by a warranty sticker. Remove all eight screws.
  • Use a plastic pry tool (never metal, as the case scratches easily) along the front seam.
  • On my unit, pushing from the back near the fan helped the case start sliding.
  • The case separates back to front and can be slid off—just be sure to depress that spring pin as it will hook on the m.2 access cutout.
  1. Notes
  • The HDMI port is located on the inside, along the side.
  • Keep the fan plugged in—if not, the system will throw loud errors.
  1. How to Access BIOS
  • Spam delete to enter the BIOS screen
  • Locate the watchdog option and disable it
  • Your screen will flicker just wait a moment until you are in the BIOS screen again
  • Now you can modify the boot loader to select your media of choice
Congrats now you can repurpose the Ugreen NAS
