Dell optiplex 3050 refurb for $146
- i5-6500, 16GB RAM, 256GB SSD, wifi, windows 10 pro license
$ 146 after use code SUMMER20SAVE
this seems like a pretty good deal if you use the ebay coupon SUMMER20SAVE
- Good Deal
- Mediocre Deal
- Bad Deal
and this HP comes in at $115 plus tax if you combine SUMMER20SAVE and also REVIVE10.
just a 500GB spinner drive though and less ram.
oh hold up, brickseek is saying walmart has this 10th gen i3 combo on clearance for $139 near me, lol
https://brickseek.com/walmart-inventory-checker/?sku=551480855
Good luck to you if you can find one!! Earlier this year, I went on a wild goose chase trying to find a similar HP i3 model at the Walmart stores within a reasonable distance from me. Unfortunately, all I ended up with was an empty gas tank. ![]()
If you can find one, they are great little boxes. I ended up buying one off eBay for a bit more and have been very happy with it, especially once you replace the HDD with an NVMe drive.
Out of stock. Personally, Iād probably avoid 6th/7th gen at this point.
