Un-modded minecraft
Minecraft Vanilla: illestmedia.net:25566
Minecraft Hardcore: illestmedia.net:25567
Minecraft Creative: illestmedia.net:25568
Textures
I’d recommend using this texture pack texture for vanilla and hardcore. Just drop the zip into your resources pack folder.
Shaders
If you want to use shaders, install optifine (you might need to click the “preview versions”.
If you can’t open the optifine JAR, download and install Java here.
This shader looks really good IMO, but you can use whatever you want.
Modded
Feed The Beast: Infinity Evolved: illestmedia.net:25565
- download & install the twitch app
- click mods in the twitch app
- install minecraft
- click browse modpacks
- sort by total downloads
- install
FTB Infinity Evolved - launch Minecraft, sign in
- select the modpack
- connect to server
illestmedia.net:25565 - map is on http://illestmedia.net:8123
