[Overview]
Since this is a pre-order, orders will not start to ship until the end-date. Orders will ship in the order in which they are received.
This combo may run again once all orders are shipped out, but the prices and other details may be different!
This combo will include:
- 2-8 x 3.5" HDDs
- Ideally 1 parity drive, rest for data
- 1 x 2.5" 10K SAS HDD
- Great for write cache, unpack/landing drive
It can easily saturate a gigabit up-link, and it doesn’t have a finite lifespan like a SSD.
[Details]
Included (free!) with every order is the following:
- 300GB 10K RPM SAS 2.5" HDD
Additional options to chose from:
- 2, 4, 6, 8, or more - 6TB SAS3 HDDs (SAS2 compatible)
- Save more as you buy more!
- Additional 3TB SAS2 HDD
[Other Info]
Cables
You’ll need some SFF-8087 to SFF-8482 cables to connect your SAS drives, the 2.5" HDD and 2.5" SSD. You need 1 cable for every 4 drives of this type.
For the SATA HDD, you can use cheaper SFF-8087 breakout cables. Again, you need 1 cable for every 4 SATA HDD.
LSI Firmware
Flashing the LSI 9211 to IT mode is super easy. You can follow this guide to do so.
Hard Drive Specs
Option 1
6TB Seagate Enterprise Capacity ST6000NM0014
- 3.5-inch, Form Factor
- 7200 RPM
- SAS3 12Gbps
- Enterprise Grade (Heavy Duty)
- 4Kn format (requires LSI 9207-8i or similar 4Kn compatible HBA)
- More info here.
Option 2
6TB HGST 7K6000 HUS726060AL5210
- 7200 RPM
- SAS3 12Gbps
- Advanced Format (AF) 512e format (no special HBA needed)
- More info here.
[Recommendations]
- Take note of which drive you are choosing. 4Kn drives require specific LSI HBA support. It’s not a big deal, just something to be aware of.
- If you’re using Unraid, consider that you will be using at least 1 HDD for parity. So your usable storage will be (N-1) HDDs worth of space.
[Pricing]
- [6TB Seagate ST6000NM0014 - 4Kn] - LINK
- 2 - $150.00 ($75.00 each)
- 4 - $290.00 ($72.50 each)
- 6 - $420.00 ($70.00 each)
- 8 (or more) - $536.00 ($67.00 each)
- [6TB HGST HUS726060AL5210 - 512e] - LINK
- 2 - $170.00 ($85.00 each)
- 4 - $330.00 ($82.50 each)
- 6 - $480.00 ($80.00 each)
- 8 (or more) - $616.00 ($77.00 each)
- [Included 2.5" SAS HDD]
Note: Make/model numbers of 2.5" SAS HDDs are not specified due to vast inventory variability.
You are guaranteed the capacity and RPM you select.- 300GB 10K SAS2 HDD - $0.00 - INCLUDED ($8.00 value)
- [Optional - 3TB SAS2 HDD]
Note: Make/model numbers of 3TB HDDs are not specified due to vast inventory variability.
You are guaranteed the capacity and RPM you select.- Add 3x3TB SAS2 HDD - $42.00 - ($14.00 each)
- Add 6x3TB SAS2 HDD - $80.00 - ($13.33 each)
Pre-orders close September 6, 2020 at Midnight PST.
Countdown timer here.
