I’ve already built 2 or 3 computers before but this is my first time building a NAS (which so far looks the same).
My setup is mainly to use with Plex and hosting for around 8-10 users, most of the movies/series are in 720 or 1080p, small part in 4K. There will be 2 to 5 users at the same time, I’m planning to use UnRAID as the OS.
That CPU and MOBO does not support ECC RAM. If you want Intel you would have to go for Xeon CPUs or older i3 CPUs, and the motherboards are usually more expensive.
I’m going a different route with Ryzen 3600 and B550 with a Node 804. This allows me to use ECC memory, with the drawback of not having the Intel iGPU for transcoding. I’ll have to get a good GPU for transcoding if I ever need more than the CPU can transcode.
That doesn’t mean that the motherboard supports ECC.
IMO build a dead simple NAS using refurb enterprise/server grade parts, such as the NAS Killer 4.0 or NAS Killer 5.0, and get a really cheap QuickSync box for dedicated transcoding.
Oh my bad, I didnt know that the later consumer Intel CPUs had ECC support. But yeah, the motherboard you selected does not support the ECC RAM, so you would either have to replace the motherboard or RAM for it to boot at all.
