Badblocks found on new 14TB IronWolf Pro
Hi
I have a brand new external seagate 14TB HDD delivered from b&hphoto to New Zealand. It was quite a good deal at only $225 USD landed.
I ran a long test using seagate tools and it passed. I shucked it and removed the Seagate IronWolf NAS Pro HDD inside and put it inside my plex server.
I ran a destructive badblocks test (takes 148hrs) and it found 385 badblocks (ie 0.00001% of blocks)
$ sudo badblocks -b 4096 -wsv /dev/sdc
Pass completed, 385 bad blocks found. (6/0/379 errors)
That’s 6 read / 0 write / 379 corruption errors.
$ sudo smartctl -a /dec/sdc
I’m not sure if having some badblocks on a 14TB HDD is an issue, as I’ve read that it’s fairly normal for a brand new HDD to have some badblocks during manufacturing and it’s only an issue if additional bad sectors crop up.
I’m not sure what to do, whether I should enquire about a return or not??
I’m just doing a smartctl long test now.
Maybe ask on Reddit r/datahoarder
I’m curious what the answer is myself. I thought hard drives handle/replace their own bad blocks seamlessly in the background so if a drive in use has reportable badblocks errors that’s a bad sign - but maybe yours hadn’t discovered them yet.
Return the drive. 14TB WD Easystores are $200 at Best Buy right now!
I’m planning to. I’m in New Zealand so can’t shop at best buy
