I’ve been running PMS for several years on an old desktop that recently crapped out on me using external HDs for storage. I’ve been lurking here a long time thinking that one day I would build my own server/NAS. Well, the time has finally come. After reading alot, I’ve decided that I want to build 2 separate boxes. 1) a rack mounted Unraid NAS with plenty of room to upgrade/expand in the future and 2) a HP S01 transcoding box.
I will probably play around with some other VMs, Dockers, jails what-have-you, but the main purpose for these boxes is to store and serve my media as it expands and act as a personal cloud (probably using something like Nextcloud).
So, here’s my first draft build. I’ve never built my own computer or anything so I could really use your assistance and advice on this. I’m looking for the best bang for my buck, but also have a little room to expand as I go. Let me know if you see anything that doesn’t look right or if you have a better deal I could go with.
For the NAS (I think this is a NK4.0):
| Part | Description | Price |
| Chassis | Rosewill 4500U | 219.99 |
| CPU | Intel Xeon E3-1270 v2 | 50 |
| Motherboard | Supermicro X9SCM-F | 50 |
| RAM | 4x8GB DDR3 1600 ECC UDIMM | 159.99 |
| SSD for cache | Pioneer 512GB | 48.99 |
| HDD | 8x Seagate 6TB SAS3 7.2K 3.5 HDD | 472 |
| Power Supply | EVGA 750 N1 | 54.99 |
| CPU cooler | Arctic Freezer 7X | 24.8 |
| SAS HBA | LSI SAS 9211-8i | 30 |
| SAS Cables | 2x Cabledeconn SFF 8087 → 8482 | 33.98 |
| Case Fans | Arctic P12 PWM 120mm 5 pack | 35.99 |
| Case Fans | Arctic P12 PWM 120mm fan | 9.46 |
| Case Fans | 2x Arctic F8 PWM 80mm | 15.98 |
| SATA cables | Relper Leneso 6 pack SATAIII | 9.99 |
| SATA power cables | Cable Matters SATA → SATA power splitter 2 pack | 11.99 |
For the S01
| HP S01 | HP S01-Pf1013w Celeron G5900 4GM RAM 1TB HDD | 159.77 |
| NVME | Acer FA100 1TB | 87.99 |
| RAM | PNY 16GB Kit (2x8GB) PC4-21300 DDR4 2666MHz CL16 1.2V DIMM Desktop RAM Memory | 49.99 |
Hopefully, this all makes sense. I am also in the market for a decent rack if anyone knows of any good deals.
