Modified this existing mount::
https://www.thingiverse.com/thing:4081201
Modified from the source file to 42 degrees. Made the model solid and printed at 50% infill. I drilled holes for the Amcrest mount, used the stock screws to mount the bracket to the wedge, and then used construction adhesive to attach it to the brick.
My modified mount:
https://www.thingiverse.com/thing:4462852
