Just really need to downsize. A lot of stuff around here other people could probably get a lot better use out of. All items/systems tested and known good working. Paypal payments preferred. Shipping by USPS tracked or UPS tracked, depending on rates. Only shipping to United States at this time.
New Additions (10/11/2021)
Acer Spin1 Laptop
- Lightly used, still with original packaging
- Intel Pentium n5000 (4 core/4 thread)
- 11 inch 1366x768 IPS touch enabled display
- 2-in-1 flip around style laptop (can do tablet and tent modes)*
- 4 GB RAM (soldered) and 64 GB EMMC (soldered) with no expansion options except a MicroSD card slot
- HDMI out, two USB ports, one of which is USB 3.0 and one is USB 2.0
- Full Windows 10 Home
- Very thin and light, textured plastics
- Notes: If I may make a personal mention - I actually love this thing, it was perfect for my light needs but I’ve upgraded to something else. Important mention: It IS an IPS display, but at anything other than full brightness… I’ll be honest it looks pretty bad. Viewing angles, mostly. And by the same token, it can do the tablet and tent modes but the viewing angles make these options basically unusable. However, the laptop itself is in basically like new condition. Battery lasts a really really long time but it is low power and I did do basically nothing except edit text on it, so YMMV.
- $190 shipped
NK4.0 Combo CPU/RAM/motherboard
- X9SCM-F motherboard with Bios version 2.3a (microATX)
- Xeon E3-1220v2
- 8 GB (2x4 GB) DDR3-1600E Unbuffered ECC RAM
- Includes IPMI onboard as well as 2 Gigabit Ethernet ports plus one Ethernet port for Management
- VGA for onboard graphics only (not compatible with CPU iGPUs)
- 2 SATA 6.0 Gbps ports and 4 SATA 3.0 Gbps ports (SATADOM compatible)
- Serial port plus two USB ports
- 2x PCIe 3.0 x8 slots
- 2x PCIe 2.0 x4 slots (x8 physical slots)
- Thermaltake Gravity i2 CPU cooler (not installed for shipping)
- $145 shipped
- Inventec B400GD0 motherboard (ATX)
- Xeon E3-1220v2
- Includes 2 Gigabit Ethernet ports on board plus VGA for onboard graphics only (not compatible with CPU iGPUs)
- Onboard SAS controller with 2 ports for up to 8 SAS/SATA drives natively - breakout cables included
- 2 PCIe 3.0 x8 slots (one openback) plus 1 PCIe 2.0 x1 slot and 1 PCI slot
- **175 shipped **
Pictures Coming
Frankly, it hasn’t been disassembled yet so it’s not quite photo ready.
Components
Netgear GS908E 8 port Gigabit Managed switch
$50 shipped
SALE Pending
BFL 850 watt PSU. One new in box, one unboxed and tested but never used used. Fully modular power supplies, all original cables included.
$100 shipped, each
4 Port SATA 6.0 Gbps PCIe x1 card
$30 shipped
2 Port SATA 6.0 Gbps PCIe x1 card with RAID function
$30 shipped
2 Port SATA 6.0 Gbps eSATA PCIe x1 card with RAID function
$30 shipped
16 GB (4x4 GB) DDR3 1600MHz RAM
- Regular consumer RAM, not registered, not ECC
- CAS 9-9-9-24 1.50v as pictured
- Lightly used
$60 shipped
Intel Core i5-2500k
- 2nd generation 4 core/4 thread LGA 1155 CPU
$30 shipped
SOLD
Intel Pentium Gold G5400 CPU
- 9th generation 2 core/4 thread LGA1151 CPU
- Used but original retail packaging
- Stock Intel CPU cooler included
$65 shipped
SOLD
Intel Core i5-9400T (2 Available)
- 9th generation 6 core/6 thread LGA1151 CPU
- low power (35w TDP)
* $125 shipped
Intel Core2Quad Q9550
- Core2Quad 4 core/4 thread LGA775 CPU
$25 shipped
Intel Gigabit NIC (PCI)
- Intel Pro/1000GT
- This is a PCI NIC, not PCIe!
- New in Box
$16 shipped
Nothing exactly to see, it’s still sealed in a plain cardboard box. I will open it if you are interested and want to see it.
SOLD
Gigabyte H370M-D3H
Used, fully functional. Takes 8th and 9th generation CPUs
- Includes mainboard plus CNVi Wifi 5/BT add-in with dual antennae and antenna bracket, original backplate, manual and retail box.
- Features include dual m.2 slots (one is 4 lane and one is 2 lane) and USB 3.1 Gen 2 onboard with one USB-A port and one USB-C port.
- Two SATA cables available if you’d like for no additional charge.
- ~~$70 shipped ~~
Gigabyte B3650M-DS3H WIFI-Y1
Barely Used, fully functional. Takes 8th and 9th generation CPUs
- Includes mainboard with onboard Wifi 5/BT with dual antennae and antenna bracket and original backplate.
- Features one m.2 slot
$70 shipped
Ivy Bridge Motherboard/CPU combo
- Intel i3-3220 2 core/4 thread CPU, installed, never overclocked
- Gigabyte GA-Z68MA-D2H-B3
- Stock Intel CPU cooler installed
- Includes i/o shield
$60 including shipping
- Intel i5-3570k 4 core/4 thread CPU, installed, never overclocked
- 16 GB RAM (4x4 GB DDR3-1600)
- Zalman CNPS 8900 CPU cooler installed
$160 including shipping
Systems
Intel NUC NUC7CJYH
Eighth Generation Intel NUC with Celeron CPU
- Intel Celeron J4005 2 core/2 thread with UHD Graphics 600
- 8 GB RAM (2x4 GB DDR4-2400 SO-DIMM) not installed but can be upon request for no additional charge (8 GB is also the max supported configuration)
- no storage included, but can accept 1 2.5 inch SATA device (15mm height does not fit)
- Full size SD card slot (UHS-I supported)
- Integrated Wifi and BT onboard
- Notes: two HDMI 2.0a ports, apparently integrated gigabit ethernet is Not an Intel controller if that is important to you, but the Wifi is Intel, and as of this writing we’ve found that Plex HW transcode is not or not well supported on this machine.
- NUC is in nearly new condition, comes with power adapter and cord and VESA mounting bracket, all in original retail packaging.
$150 including shipping
Intel NUC NUC5i7RYH
Fifth Generation Intel NUC with i7 CPU and better integrated graphics
- i7-5557u 2 core/4 thread CPU with Intel Iris Graphics 6100
- 8 GB RAM (2x4 GB DDR3L-1866 SO-DIMM)
- no storage, but can accept 1 m.2 nvme or SATA device plus one 2.5 inch SATA device (15mm height does not fit)
- Includes Wifi and BT onboard
- no OS included
- Power Adapter included
- Notes: strange scuff pattern on the black plastic lid. Not sure what it is, but I received it that way when I bought the NUC second hand. Also there is one jagged scrape across the back, also from first owner. Other important note: has HDMI out but it is physically mini-HDMI. One adapter will be included for your ease of use. Last important note: has Liquid Metal applied as the CPU thermal material.
- $200 including shipping
SOLD
HP290-p0043w with 4 GB RAM 16 GB Optane:
HP290 Has been opened, powered on, but is unused and is like new.
- Celeron G4900
- 4 GB RAM (1x4 GB DDR4-2400 DIMM)
- 16 GB Optane m.2 drive installed
- Note: original Wifi/BT card and antenna removed, also, Power Button LED doesn’t seem to work.
- Optical Drive
- Includes just the system, but keyboard and mouse and power cord available on request for no additional charge
$120 including shipping
SOLD
HP290-p0043w with 16 GB RAM and 256 GB nvme:
HP290 Has been opened, powered on, customized and briefly used but is like new.
- Celeron G4900
- 16 GB RAM (2x8 GB DDR4-2400 DIMM)
- 256 GB nvme m.2 drive installed
- Original Wifi/BT card and antenna included
- Optical Drive
SOLD
HP290-p0043w with 8 GB RAM:
Nearly stock HP290 but with 8 GB RAM. Has been opened, powered on, but is unused and is in very good condition.
- Celeron G4900
- 8 GB RAM (1x8 GB DDR4-2400 DIMM)
- 500 GB Hard Disk Drive with original installation from factory including Windows 10 Home
- Original Wifi 5 with Bluetooth and original antenna
- Optical Drive
- Extremely minor scuffs on back cover pull tab. Barely anything, but I figure I should mention.
