So standard issues with finding affordable parts in Europe/UK made me think the easiest option is to just go pre-built.
Reading both Build Guides doesn’t make it clear what the differences are between the two and why you should go for one rather than the other. Can anyone elaborate?
Also, does anyone in Europe have experience of what Prebuilts are typically good value? I’m looking for a dual Xeon system capable of holding 10+ drive bays (DAS is okay if not too pricey).
