Other than losing space, is there any benefit in leaving the drives at the 7.86tb size, do the extra parity bits help with sector/block recovery on the drive itself? Or does that require having a controller/software designed to take advantage of that parity?
Working on trying to get some of the 8tb drives to replace some aging 3tb drives in my Unraid server. So if there is an advantage to leaving the parity bits there, then I’m find with keeping them at 7.86 because that’s still more than double what I am replacing.
In the user guide for the hugo tool, under format there is an option for protection type (0,1,2,3) but it doesn’t say what the different types are. Is the default no protection?
Yep, default is 0 (disabled). Note that hugo’s fast format is also not meant to work with unlike sector sizes (e.g. 520 → 4096, or 512 w/protection enabled).
Did you change out sdX with the drive letter of choice? I just did this for 4 of the drives in my system and had no problems getting the full capability.
I have not done it yet, this is a long thread with various different attempts so I just was looking for confirmation of the correct commands to be ran - of course changing to the needed drive letter.
Did you run sg_format --format --size=4096 /dev/sdX or sg_format --format --fmtpinfo=0 /dev/sdX
Hi, hopefully someone here can help me.. I’ve made a mistake. I have a Dell r510 with a perc H700 raid controller, I installed my 8tb sun HGST set it up as raid 0 and it was found in windows but was missing some capacity.. I did a Hugo format in windows to 4k. Problem is now the drive isn’t being recognized anymore. Its showing up in the H700 bios but only as a 900gb drive.. if i try to make a Raid 0 with the drive it fails. I’m not very good with Linux & obviously windows also LOL!.
Is it possible to format this drive again with Linux?
If so how do i get the drive recognized and ready to format back to 512b
Hello all. Looks like I am a year late as I see that the last message was posted in March of 2023.
I am having an issue formatting an HGST 8TB drive Model #HUH728080AL5201 (Netapp) The drive appears to be fine except for the fact that I am unable to format it from the ubuntu command line. I have tried both sg-utils and Hugo. I tried most if not all of the suggestions made here and elsewhere to no avail. Your time and assistance will be greatly appreciated. I hope that it is alright that I attached several screenshots to this post.
Thank you @stuffwhy I don’t mind listing the cli commands that I used in sg_util and Hugo if that will help. I have had another HGST Sun/Oracle SAS 8TB HUH7280805200 drive installed and had no issued formatting that.
Hi, I have the EXACT drives as you and have found this thread in my attempt to reformat them, not sure if you’ve found a solution, I was finally able to get sg_format to work, detailed here:
The trick is we have to unlock the drives with sedutil-cli using the PSID code on the printed drive label next to the QR code
