Hey y’all, working on transferring data out of my white-box frankenserver and onto a proper NK4 I’m building, looking for some feedback on how I’m going to go about doing this. I’ve written up a small doc for myself to follow, anyone mind double checking it to see if I’m missing any important parts?
TL;DR “copy data to NAS, hook up Plex to NAS, remove original data sources, max downtime of like 30 minutes or so”
Operation Valkyrie
Objective: Transfer all data off RA41
white box to Urdarbrunnr
NAS, with minimal downtime for Plex users.
Starting Information (As of 2019-07-26) :
- 34.05TB of media on
RA41
RA41
gains data at (an average of) 81.3GB per day.- This is realistically closer to 4.71GB per day (for shows alone) but we are considering worst case scenario.
Requirements of Urdarbrunnr
- Hold
RA41
data immediately - 3x10TB Had Drives
- Expected final NAS+DAS to hold 30x10TB drives, I’m going to pre-allocate 2 for parity.
- We can take 2x10TB and 2x8TB from
RA41
to work with, giving 36TB of raw storage to work with.- That margin is small to require another 10TB drive
Plan of Action
- Assemble
Urdarbrunnr
(I’m covering my bases here) - Begin data transfer between
RA41
andUrdarbrunnr
- This will take approximately 4 days (assuming no errors and 800Mbps consistent throughput)
- Wait for low-user time before continuing
- Connect
RA41
Plex instance toUrdarbrunnr
, verify all files duplicated and are identical- Who doesn’t love a good python script to read through the DB?
- Verify transfer suceeded and data will show as ‘deleted’ properly
- Shutdown
RA41
, unplug drive with least media on it - Online
RA41
and verify data is only available onUrdarbrunnr
- If not,
panicdetermine better path to follow (since no data has been deleted) - Repeat Step 4 until verified.
- If not,
- Shutdown
- Remove drives from
RA41
and delete unavailable content- Only remaining data at this point will be on
Urdarbrunnr
- Remove references to removed drives from Plex
- Celebrate succesful transfer
- Drink heavily.
- Remember you have to take drives out of
RA41
and add them toUrdrabrunnr
- Drink heavier.
