Will be updated with the latest arctic heatsinks soon
Heatsink overview
Compatibility matrix
| single 115X ATX | dual 1366 EATX | dual 1366 ATX | single 1366 ATX | dual 1356 ATX | dual 2011 EATX | dual 2011 ATX | single 2011 ATX
Arctic Freezer i11/i11 CO |yes|yes^A|yes^A|yes^A|yes^A|yes|yes|yes
Arctic Freezer 12/12 CO |yes|yes^A|yes^A,B|yes^A|yes^A,B|yes|yes^B|yes
Arctic Freezer i32/i32 CO/i32 Plus |yes|yes^A|yes^A,C|yes^A|yes^A,C|yes|yes^C|yes
Arctic Freezer 33/33 CO/33 Plus |yes|yes^A|yes^A,B,C|yes^A|yes^A,B,C|yes|yes^B,C|yes
Arctic Alpine 20 Plus CO |no|no|no|no|no|yes|no^D|yes
Legend
A: Use 115X screws in 2011 mounting pattern for compatibility (ignore manufacturer specs.)
B: Will work if you have memory without heat spreaders
C: Low profile memory will clear the heat pipes better, regular memory may slightly touch or block heatpipes.
D: Fits the socket fine, but sockets are spaced too close for these heatsinks.
